<~----> question on D5 upgrade kit - Hardware Canucks
Old October 10, 2012, 07:35 PM
fyshawk's Avatar
Default question on D5 upgrade kit
Dual / Single D5 Top Upgrade Kit 150 (Black POM Cap)
I am wondering if this will work with my fittings
Compression Fitting - 7/16" to 5/8"
and my water blocks
EK-FC6970 Full Cover Block and HEATKILLER CPU Kuhler Rev3.0
wil be using
Mayhems Aurora - Tharsis Red Coolant Concentrate
or i will reuse my
IceDragonCooling Nono Fluid - White
Intel I7 950 / Water Cooling
Asus Rampage III Formula Rog X58/3 x 1Tb hard drives
12 gig Corsair Vengence 1600 3x4/SAphire 6970 2 gig
Corsair 800D case /750AX Corsair PSU
3x Samsung E2320 Lcds in Eyefinity
Old October 11, 2012, 06:34 PM
Astaroth's Avatar
As long as the pump top, blocks, and your fittings are G1/4 you should be fine.
Upgrade question. chewtoy0 Video Cards 4 October 21, 2010 05:15 PM
Upgrade to SSD question Vdub90 Storage 14 February 10, 2010 10:06 AM
upgrade question tri5cui7 CPU's and Motherboards 11 February 9, 2010 09:50 PM
Upgrade Question boing CPU's and Motherboards 1 August 16, 2009 07:20 PM
Videocard upgrade question r0bc Video Cards 8 April 18, 2009 11:13 AM
