-   -   Gigabyte GV-R6970C Rev1 Waterblock (http://www.hardwarecanucks.com/forum/water-cooling/57086-gigabyte-gv-r6970c-rev1-waterblock.html)
krankedmusic October 4, 2012 04:37 PM
3 Attachment(s)
I am looking for a water block for this card. It seems gigabyte might not be able to take any of the water blocks other then the single gpu block. Any chance anyone knows of a manufacture that might make blocks that fits this card?
If you can see the picture below the transistors sit really close to the ram modules. if you look at the ati reference it should be further away.
canada2005 October 6, 2012 06:51 AM
That looks like a 6970 OC Windforce. If it is, it is not reference. You might only be able to get the universal gpu blocks on there.
Check these from Daz.
Raystorm GPU
EK GPU
Good luck
