-   -   Bleeding swiftech mcres v2 (http://www.hardwarecanucks.com/forum/water-cooling/56949-bleeding-swiftech-mcres-v2.html)
geoc September 26, 2012 11:45 PM
Well, the bug has bit me again, and I am doing a new loop for a computer that doesn't even exist (i'll buy parts for the loop later).
Right now I am having issues with the swiftech mcres v2, it seems like that all the bubbles that get pushed out get sucked right back into the pump. I have left the loop on for hours, and large bubbles are still circulating through the loop(you can see them zip by in the tubing)
There is very little flow restriction in the loop as well, so no bubbles are getting trapped in the rad or whatsoever.
I am using the 2 middle vertical holes for the nozzles, with the lower one being the outlet to pump.
sswilson September 27, 2012 03:16 AM
I don't have one right in front of me to verify, but I believe the lower hole points towards the plastic difuser (there's an internal plastic "shelf"). If that's the case then the lower hole should actually be your return so that the bubbles hit up against it.
geoc September 27, 2012 04:38 PM
I switched nozzle orientation, and still to no avail.
There's a lot of turbulence and sloshing inside the mcres and even when filled it up. It acts nothing like the ones people posted on youtube.
lowfat September 27, 2012 04:49 PM
What so you have for the rest of the loop? Do you have a way of slowing down the pump speed?
geoc September 27, 2012 04:52 PM
MCP350 w/ EK-DDC X-TOP v2, mcr320, unknown wb, and the mcres
lowfat September 27, 2012 06:03 PM
You have too much flow. Slow down the pump somehow or add more restriction to the loop. Not much else you can do. The MC-Res is already the easiest small reservoir to bleed that I know of.
geoc September 27, 2012 06:36 PM
Too much flow? And I was thinking of turning it into 18w.:doh:
Any suggestions as how to restrict flow?
lowfat September 28, 2012 10:15 AM
The easiest would be to get some sort of fan / pump controller and slow the pump speed to get it bled fully.
Another option, if possible, would be to put a sponge in the reservoir. One similar to the ones used in the Swiftech MCP35x tube reservoir. Not sure if you can get a sponge to fit in the MC-Res though.
KaptCrunch September 28, 2012 03:30 PM
simple cheap solution http://www.preservationequipment.com...mb?w=283&h=283 use a pair of needle nose pliers
on the pressure side of pump by pinching the outlet hose closed . this will slow flow enough to dispurse bubbles, once done remove pliers and your set to go.
if bubbles still happening after this operation then cavitation issue
geoc September 29, 2012 01:27 AM
1 Attachment(s)
Thanks guys, I finally managed to get it bleed out all the bubbles. Funny enough, it took less than 15mins to fully bleed once I got it going.
Anyways, I decided to mod the pump to be switchable 10/18w. So I choose high power or low power whenever I want.
Unfortunately, you cannot switch the power on-the-fly, but you have to shut off the pump first ( I assume the microproc detects the signal at power up)
Here's a pic: (and Varroa, your pump is in good hands :) )
