Old April 20, 2008, 04:16 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Default WC project and need source for part source
Does anyone know of a Canadian retailer who has either the D-TEK FuZion in stock or the Swiftech Apogee GTX's copper housing? I'm putting together a WC kit to cool off my fireball 9450(1.16v @ 400FSB = 50°C on idle 62°C load w/ Ultima 90 + Nocuta P12). Needless to say its time to step backinto the wonderful world of WC'ing...and I though I had kicked the habit ;)
Anyways here is what I thinking as a simple little loop:
Fuzion or GTX w/copper top CPU block
mcp655 (though I might drop down to a Dtek DB1 for lower noise)
MCR220 dual rad w/ res built in
rad box
tygon 1/2 ID tubing
d-tel High flow g1/4 barbs
fesser one non conductive coolant (might drop this)
4 Noctua p12s in push pull config.
and enough steel worm hose clamps
I've gotten everything else sourced w/ ncix but that darn Dtek! HELP!
Old April 20, 2008, 04:43 PM
Wankerfx's Avatar
D-TEK Customs Fuzion CPU Water Block S478/LGA775/S939/AM2/S754 1/2IN Barbs - DirectCanada
They usually get new stock in weekly.
I'd also recommend upgrading to a MCR320 for a few more dollars with three Yate Loon fans.
[ER]
Old April 20, 2008, 04:51 PM
AkG's Avatar
AkG AkG is offline
I would love to go triple rad (or heck a double thermochill ) but the case is a CM690 and dual swiftech rad is about as big as i can go. As for the yate loons...to noisy (used them in the past) and the Noctua NF-P12s are quiet and have kick ass static pressure.
Thanks for the link, but I tried there already and they are "not available" right now. I'll keep an eye DC but am not too hopeful. Dteks seem to be getting hard to find :(
Old April 20, 2008, 04:53 PM
Default Reply
WARNING: Aluminum+Copper=Corrosion
I too would upgrade to a MCR320, and get a separate reservoir which in turn would improve liquid flow. Also let me tell you this, Noctuas are not necessary instead settle for some Scythe S-Flex's. The Scythe's perform on par, are cheaper by about $7 bucks per fan(7x3fans=$21), and also look MUCH better.
EDIT: NVM about the MCR320...
Old April 20, 2008, 04:57 PM
AkG's Avatar
AkG AkG is offline
I use Scythe's all the time (especially in my reviews) and Scythe Fs are extremely loud when compared to Noctua's; worse they are not as good when it comes to static pressure. Minor Price dif not much of a concern, noise levels number 1 concern (after lower temps). I'll probably upgrade the case and the rad to a thermochill + p182 later, right now short term not too worried about corrosion.
Old April 20, 2008, 04:59 PM
Cptn Vortex's Avatar
I emailed Linus @ NCIX and he said he should be getting some Fusions in the next week or so. As for the copper top for the GTX, it would be special order, a couple weeks at best.
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old April 20, 2008, 05:01 PM
AkG's Avatar
AkG AkG is offline
Sweet! Thanks Cptn Vortex. I hate settling for 2nd best if I don't need to ;)
Old April 20, 2008, 05:18 PM
Yeah I know. Thinking of upgrading to the Fusion, just for the heck of it. However I now see the XSPC Delta block, and it looks darn Nice. I might see if I can get my hands one one....
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old April 23, 2008, 01:11 PM
Try this place for the apogee.
NTCW.com....A Online Computer Store - Product List
Old April 23, 2008, 07:40 PM
Default Reply
Since it looks like a CPU loop only, may I be bold enough to recommend an EK Supreme.
