-   -   I7 3770K watercooled (http://www.hardwarecanucks.com/forum/water-cooling/56737-i7-3770k-watercooled.html)
zati September 16, 2012 05:11 AM
Hi,
I'm looking to put watercooling in my case but the problem is that I don't have that much space to put a radiator and I'm not eager to place it outside the case (case is a Aerocool Xpredator)
I can probably fit 2 140mm rads from ek water blocks in my case, 1 in the back and 1 at the bottom but will that be enough to cool the mb (asus maximus v formula) and the cpu oc at 4.4 or 4.6?
If anyone has experience with those rads, what temp should I expect given the cpu is at 4.6?
Evochuck September 16, 2012 06:27 AM
2x 140 realy isnt all that much of raddage.
BUT according to the internets, you can install a top rad of 2x140mm without modification and if you were to grab a dremel you could probably fasion yourself a nice opening of for a 3x140 rad!
check those pics out
http://galeri.pclabs.com.tr/cache/ae...g_2705_600.jpg
http://galeri.pclabs.com.tr/zp-core/...&wmk=watermark
