-   -   Fans needed for Corsair H100 (http://www.hardwarecanucks.com/forum/water-cooling/56617-fans-needed-corsair-h100.html)
Alpine September 9, 2012 01:29 PM
hello guys.
I need fans. Thoses are coming with the H100 are very too loud. I need 2 120mm that can push air and very quiet too....
Any recommendation ??
[nK]Sharp September 9, 2012 01:52 PM
Gentle typhoons.
Adzsask September 9, 2012 02:12 PM
Gentle typhoon AP-15's or cougar CFV-12HP's, I prefer GT's they have a unique noise that does not bother me at all.
stoanee September 9, 2012 02:39 PM
Gt's 1850 rpm.
Inik September 9, 2012 02:53 PM
GT 1850 :)
I like their sound with my H100
Alpine September 9, 2012 05:03 PM
How is the cpu temperature you get with the Typhoon fans ?
NSdeadly1 September 9, 2012 05:50 PM
Corsair SP120's. They've dropped my temps considerably.
rovert September 9, 2012 06:53 PM
I use gentle typhoon 1450 and they are very nice. It has a soothing sound and works very effectively as well.
Silent_Avenger September 9, 2012 10:37 PM
According to the stats of the corsair SP120s they seem to be like a very good fan for the H100.
BigPhatPaulie September 10, 2012 07:35 AM
The thing is though the GT 1850's are basically silent at full RPM while ive heard many reports that the corsairs arent... for some this isnt an issue but its a noticeable difference
