Old April 18, 2008, 12:45 PM
Infiniti's Avatar
Default Better waterblock than D-Tek Fuzion CPU WB?
I've been looking for reviews for this WB lately and it seems that its better than the Fuzion CPU WB. Is this true?
Old April 18, 2008, 01:34 PM
Cptn Vortex's Avatar
In some cases yes, but it is also more restrictive. This means it is best used in a CPU only loop, and not very good if you have a VGA or Chipset block in the same loop.
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old April 18, 2008, 10:00 PM
Infiniti's Avatar
So.. then whats another CPU block thats not too restrictive? I'm going to be cooling my GPU, NB, and SB, so I need a block thats not restrictive...
Old April 18, 2008, 10:13 PM
lowfat's Avatar
What is wrong with a Fuzion?
Old April 18, 2008, 11:52 PM
Infiniti's Avatar
I'm ordering real soon and its out of stock..
Old April 19, 2008, 12:48 PM
Infiniti's Avatar
Also, this might be off-topic... anyways, is a full coverage WB for the GFX better than something like the Fuzion+UNISINK combo?
Old April 19, 2008, 05:30 PM
Infiniti's Avatar
bump
Old April 19, 2008, 08:08 PM
ChuckleBrother's Avatar
People seem to swear by both, my FC block seems good, and I dont mind the hit to my overall temperatures, though they are LARGE. If you're worried about warping, then go with the smaller block.
"...you play a mean banjo"
Old April 19, 2008, 11:10 PM
Infiniti's Avatar
I'm just going to get the GT now... thx anyways
