Old August 13, 2012, 03:54 PM
tangrisser's Avatar
Default Arctic Cooling Accelero Hybrid!
This is pretty exciting stuff. I'm a big fan of closed loop water cooling heatsinks. This one almost does it for video cards.
Accelero Hybrid 7970 · VGA · Cooling · ARCTIC
It's a little disappointing that it's not flush with the card but it's trying to be universal and hence the nasty design and the fan.
It's a little expensive but if enough manufacturer start producing this or something similar to this. It would drive price down. I really dislike the fan but I wonder if it can do away without the fan if there is enough airflow in the chassis.
What do you guys think?
Check out my SALE page
Old August 13, 2012, 04:19 PM
BigPhatPaulie's Avatar
Eh at that price it doesnt do anything for me. IMO either get a card with good cooling from the big 3 (asus, msi, gigabyte) or go custom on it. Its a neat idea but seems like a bit of an overcomplication. Also that fan is necessary because how else would the vrm's get cooled properly?
FOR PONY..... that is alll
Old August 13, 2012, 05:27 PM
Adzsask's Avatar
:O I did something simmilar to my graphics card... cost was $52 for an antec kuhler 620, and a universal bracket to use h50/70 kuhler 620/920 coolers on AMD/intel graphics cards. Pulled the shroud and vapor chamber off of the stock cooler on the card, turned the fan to 50% and PCB stays at 46C while gaming/folding for hours straight.
http://i183.photobucket.com/albums/x...8_120211-1.jpg
Old August 14, 2012, 05:09 PM
tangrisser's Avatar
Wow. That's pretty sweet.
What about the VRM and RAM? I don't see any 3rd party heatsink on your mod.
Old August 14, 2012, 08:38 PM
Adzsask's Avatar
just the stock evga sink under the vapor chamber, 46C max on the vrm's.
Old August 14, 2012, 09:36 PM
Fudd Rucker's Avatar
I believe there is a guy on another site , cant think of which one off the top of my head that will custom make brackets to stamp closed loop coolers on cards. I myself was planning on doing this with my itx build as I dont feel like fighting with a custom loop lol.
I couldnt think of something snarky or interesting to put here this time around.
Old August 15, 2012, 09:18 AM
tangrisser's Avatar
It's too bad video card manufacturer didn't standardize the heatsink mounts even by one brand either AMD or nVidia. I think it might have saved them some cost by standardizing across some of the higher ends at the least. (ex. 7970, 7950, 7870, 7850) but of course, that makes things just to easy. qq
Old February 25, 2013, 11:02 AM
LW_Black4's Avatar
I agree that Arctic Cooling Accelero Hybrid is not pretty added to a card, but it has a lot of charm as a cooling solution. I saw one installed with the Accelero Hybrid radiator at the bottom of the case drawing in, and a separate CPU cooler at the back of the case drawing in. Interior air was being vented out of the top of the case.
In a modern system the only two components that really develop significant heat are the CPU and GPU, and if you can cool them both with a closed-loop liquid cooler then the thermal environment inside the case becomes a lot less important.
You can push a system almost as hard as you want then and it won't break a sweat, and interior temps will be managed easily with a few standard case fans.
It's only when one starts jacking the gear up way beyond it's rated specifications that this setup is going to reach it's limitations.
It's ugly, but the cooling performance is stellar and it's got some serious charm as part of a complete case interior thermal solution.
Buckle up. The new WRX STi is here.
[FS] Arctic Cooling Accelero XTREME 4870X2 AmuseMe Buy/Sell & Trade 15 January 16, 2010 07:04 AM
Arctic Cooling Accelero TWIN TURBO Pro Cooling for GPUs FiXT Press Releases & Tech News 6 November 16, 2009 12:51 PM
Arctic Cooling Accelero Twin Turbo Pro mattlef Air Cooling 3 September 25, 2009 08:23 PM
Arctic Cooling Accelero Xtreme fans Infiniti Video Cards 5 August 19, 2008 12:57 PM
Arctic Cooling Accelero Xtreme Kopi Rumor Mill 5 November 28, 2007 09:19 AM
