Old August 9, 2012, 03:12 PM
Overclocking.ca's Avatar
Default GPU Water Block Question
I have a question concerning the GPU water block.
First off I have sold my two 560Ti's. I plan on getting the EVGA GTX 670 FTW (02G-P4-2678-KR) and from what I read it uses the GTX 680 PCB. With that said I know I need to get a water block for the 680. I have narrowed it down to the following:
EKWB - EK-FC680 GTX - Acetal - Copper Full Cover Block for GTX680
EKWB - EK-FC680 GTX - Acetal+EN (Nickel) Full Cover Block for GTX680
The CPU water block will be the XSPC Raystorm.
My question is if since the Raystorm uses a copper base should I get the cooper water block or will nickel one work?
I read that using different metals can cause issues with the loop.
My other question is there any other place in Canada that you can order the EK backplates? Daz doesn't seem to carry them.
Thanks
Old August 9, 2012, 03:30 PM
SugarJ's Avatar
Both blocks are copper. The nickel-plating just gives it a silver finish. Either can be used.
Old August 9, 2012, 04:45 PM
I just found out by Daz that both those blocks are discontinued and they only have these ones.
Personally I think they are fugly.
Anyone got any recommendations?
Old August 9, 2012, 05:18 PM
lowfat's Avatar
New EK stuff is hideous IMO. Watercool would be my choice for blocks.
https://www.dazmode.com/store/produc...er_waterblock/
Old August 9, 2012, 05:32 PM
Bungwirez's Avatar
lol... you can't even see the fugly part once its in your case.
If you don't like funerals, don't kick sand in Ninja's face
Old August 9, 2012, 05:51 PM
lowfat's Avatar
The Watercool backplate also looks really awesome.
https://www.dazmode.com/store/catego...s_accessories/
Old August 9, 2012, 06:05 PM
Do not give EK any money, go with the heatkiller linked above, it's a work of art.
Old August 9, 2012, 06:23 PM
I like the heatkillers, Daz had recommended them too.
Personally I like this one. It's a bit more money than the one you linked to.
I will be getting the backplate as well.
[WTB] Looking for old GPU with Water block botat29 Buy/Sell & Trade 1 June 29, 2012 04:39 PM
gpu water block CTA Water Cooling 9 December 24, 2010 09:59 PM
[WTB] AM3 cpu water block Fudd Rucker Buy/Sell & Trade 1 October 8, 2009 12:06 PM
Best Water Block for i7 Bubbzilla Water Cooling 7 July 7, 2009 11:54 PM
gtx 285 water block Phobia Water Cooling 6 February 24, 2009 08:20 AM
