Old August 2, 2012, 11:07 AM
lowfat's Avatar
Originally Posted by Astaroth View Post
I find the noise made by a D5 running at 24v will get drowned out by the quietest of fans. I guess the PWM gives you the benefit of performing less wear when idle thus extending pump life expectancy?
I'm pretty sensitive to my computer noise. I have to slow down my pump to ~ 2000 rpm (full speed is 4500)before I can tolerate the noise. I also run my fans @ 5V or lower if possible.
Originally Posted by NiteOwl View Post
How do you run it at 24v on a 12v power supply?
CTR-SPD24X2 Dual 24V Pump Controller
They also make them for one pump.
Old August 2, 2012, 11:57 AM
interesting. i am already not sure that my 1 655-b pump is going to be enough for the system i am building, i was going to add a mcp 350 pump that i have also in the loop somewhere. would bumping up the voltage on the 655 be a better idea for a cleaner install and still push through everything in the loop?
Old August 2, 2012, 12:01 PM
lowfat's Avatar
Don't mix and match pumps. Stick to one type. Either way you'll be fine. Flow rate is hugely overrated. You also can't bump the voltage past 12V on a D5 unless you have the D5 strong model.
Old August 2, 2012, 12:03 PM
Cool, thanks for the info.
Which MB to choose? Lucasrivers New Builds 11 March 8, 2012 03:39 PM
Help me choose a TV thenewguy001 Off Topic 1 February 3, 2011 12:25 PM
Help me choose a PSU ADay2Long Power Supplies 5 September 12, 2010 09:00 AM
Help me choose doup93 Video Cards 5 May 1, 2009 06:28 AM
Which would you choose? encorp RAM 20 April 18, 2008 09:25 PM
