Old July 15, 2012, 07:10 PM
mataribot's Avatar
Here ya go, there is a lot you can do with that case.
Snow Drift - Water Cooled 690 II Advanced 6970 1100T Gadget Show Live System - YouTube
Old July 16, 2012, 11:02 PM
ordering up the parts below, the MCR-220 Rev2 to save $24 over the Rev 3 unit. I may even go with 2 of these units therefore having 2 pumps in the loop for redundency or will stick to whats below
Swiftech MCR-220 Drive Rev3 Heat Exchangers w MCP35X PWN Integrated Pump/Res
Swiftech MCR220-Quiet Power rad w Res
Swiftech Apogee HD block
XSPC Razor HD6990 block (have already)
4x GT AP-14 bottom rad
2x Cougar or Phobya Nano G12 for top mounted MCR-220 in Push
Then just gotta find fittings!!!
Old July 30, 2012, 11:10 PM
The final list of all parts I now have except the Switch 810 case which was arrives tommorrow, next week will begin the dry build of the unit after thoroughly flushing the rads
NZXT Switch 810
Swiftech MCR220 Rev 2 (all in one mcp35x pump ,rad,res) 2 x AP-15 fans
Swiftech MCR220 Quiet Power rad/res unit w 2 x Cougar 120 Fans
Apogee HD cpu block
Lamptron Fan Controller FC5V2
3/8" Primochill Tubing
Swiftech 2 x 45 degree 3/8" x 5/8" swivel Lok-Seal adapters
Swiftech 2 x 90 degree 3/8" x 5/8" swivel Lok-Seal elbow adapters
Swiftech 4 x 3/8" x 5/8" Compression fittings
2 x Antec TrueQuiet Pro 120mm 600-1200rpm
2 x Gentle Typhoon 120mm AP-15 For MCR220 rad
2 x Cougar Vortex 120mm for MCR220 QP rad
XFX 850w Black Edition Single Rail PSU
Gigabyte P67A-UD7-B3
HD 6990
i7 2700k
180 GB PCI Express RevoDrive
2 x Vertex 2 120 SSD
2TB WD Green data
LG BD Writer 6x
Old July 31, 2012, 09:24 AM
BigPhatPaulie's Avatar
My head hurts from reading all the watercooling parts but good luck!
FOR PONY..... that is alll
Best Liquid Cooling For COSMOS II CHICKEN_jr Water Cooling 2 April 3, 2012 08:33 AM
New to liquid cooling, need advice on possible loop ToXic Water Cooling 11 December 8, 2010 06:34 AM
First liquid cooling system - advice? Kartner Water Cooling 14 April 23, 2010 07:01 PM
TEC liquid cooling. Overclocker~4.1 Water Cooling 14 September 24, 2009 07:16 PM
Dry Ice and Liquid Cooling? CanadaRox Water Cooling 13 December 27, 2008 08:27 AM
