enough flow for my loop my question is after adding component in my loop do will have enough flow? now i have 1 Gpm (taken from Koolance flow meter) this is what i have in my loop it wil be more easy with a pic http://i2.photobucket.com/albums/y15...2/IMG_1634.jpg Swiftech Apogee HD Koolance Rampage IV extreme water block 2 x Kollance HD7970 water block in serial 3 x EX360 rad a lot of 90 degree fiting a Koolance flow metter 2 x Koolance quick disconnect on this loop, i have 3.750 LpM (1 GpM) with 2 D5 Vario at speed 5 (in serial) i will had another HD7970 and 2 x EK Dominator GT water block do you think my flow will be to low? if i connect my GPU in Parallel, this will help for having a better flow? do you think my both pump will be enough??? or its a perfect setup for a pair of DDC 3.25 ? or i need to do 2 separate loop? thanks for your help |
I think your pumps are more then enough for this setup. One pump might be pushing it with 3 Rads and all those components and fittings, but two will for sure be good. I had my Video Cards in both Serial and Parallel and did not really notice a difference in temps or flow rate. |
Should be fine. So long as the fluid is moving at a decent rate you are good. Nice build by the way. |
Flow rate is hugely overrated. Anything over 0.2 gpm will be fine. I would suggest removing the flow meter though. The Koolance meters have something like a 30% pressure drop. |
The meter itself I believe. |
| All times are GMT -7. The time now is 11:44 AM. |
