I'm still undecided what to do with this. There are many options but none that seem a perfect fit.
Having the fan on the back up by the NB blowing in is a good solution for cooling the NB as well as surrounding components though I not really sure any of the other components are of any concern. However doing this creates too much positive pressure in the case since the fans on the rads are blowing into the case as well and all temps suffer. I
could just add additional fans to exhaust more air and equalize the case pressure but I don't want to avoid that for noise sake.
If I turn the fans around on the rads to blow out the bottom then another couple issues come up. First, the rads will be getting warmer case air instead of nice cool air off the floor. Second, at present the fan from the rear most rad washes some cooling air over the video card and that would be gone possibly creating other heat issues. That fan also cools the SB nicely too but that is a minimal concern.
Adding a WB to the NB I think would eliminate the need for the fan at the back of the case and I would only need the two fans on the rads for case air flow. The RAM seems to be fine with minimal to no air flow but I don't know what good temps are, I'm presently getting ~40°C on the heat spreaders. Also with no airflow around the CPU a few of the power supply components are getting up to 60° but those are the FETs and that is peanuts for discrete FETs.
I still haven't tried the 60mm fan on the NC-U6 and maybe that will be silent enough not to require and further steps but it does (as mentioned) stand out like a sore thumb.
Primu$,
here is a thread on my build, it should answer your questions on the flow. If not let me know.
