Old June 30, 2012, 02:18 PM
Adzsask's Avatar
4 if you have the room, I only lost 1C going from push pull to pull only, but I am running an RX360mm on just my CPU.(GPU has a kuhler 620 on it)
Old June 30, 2012, 02:59 PM
crawlerz246's Avatar
incidentally I have version 4 installed because somehow it made more sense to me originally. and yes, after removing the coolermaster V8, I now have oodles of room. I could fit a horse in there now, and still have room for a zebra.
Old June 30, 2012, 05:17 PM
Prolab's Avatar
I just find, having a push+pull configuration is much more noisier than push or pull. So i went with either configuration.
I usually have my rads intake air from the outside.
Gaming Rig:
-Swiffy 655 & 360 rad, 360 XSPC Rad, HK Supreme HF, EK D5 top rev.2, AMD BE 1100T OC to 4.07 ghz, 16 GB G.SKIL F3-12800CL9Q-16GBXL, Asus Crosshair V, (2) XFX 6950 w/ XPSC WB, Crucial M4 128GB & 120 GB Vertex 2 EXT, (4) 2 TB WD Green Drive, Corsair AX1200, Win 7 Pro 64-bit
Server Rig
-AMD Athlon II 245 stock, Asus Mobo, 2 GB DDR2 Kingston, WHS, 500 GB WD Black, (2) 2 TB WD Green, (2) 2 TB Seagate HD, (1) Samsung 2 TB F4, Fractal Design R3, Antec 650 watt PS
Old June 30, 2012, 05:20 PM
BigPhatPaulie's Avatar
That diagram made a lot of sense actually (and made me think of mambo#5) but mine is like this
Where the fans are outside the case so to speak and the rad is on the inside
FOR PONY..... that is alll
Old June 30, 2012, 08:00 PM
rfglass's Avatar
I have set up push pull with cougar fans ,29 degrees ambient in room,no overclock,H100 set to medium,cpu sits @ 22 degrees,pulling air in from outside case. with 1100T
Old July 1, 2012, 07:09 AM
Originally Posted by rfglass View Post
I have set up push pull with cougar fans ,29 degrees ambient in room,no overclock,H100 set to medium,cpu sits @ 22 degrees,pulling air in from outside case.it's all about dissapating heat
with same cpu?! no way! how!?
p.s. yes mine are plugged into the pump's PWM fan controllers (on max) and at stock speeds I see 35C. nowhere near 22C. coldest core is 28C. maybe I applied the paste wrong
Tags
corsair , h100
Should i get H100?? carlosespada12 LinusTechTips Q&A 7 April 20, 2012 02:39 PM
H100......this looks bad....... jonny.nguyen2 Water Cooling 18 April 17, 2012 02:27 PM
H100 trayton Water Cooling 19 March 5, 2012 11:55 AM
H100 install Mod... jef.paas New Builds 0 October 31, 2011 05:10 PM
[WTT] My LGA775 DDR3 setup for your AM2+/AM3 setup Realityshift Buy/Sell & Trade 2 April 12, 2009 05:17 PM
