-   -   Tubing and Fluid question (http://www.hardwarecanucks.com/forum/water-cooling/55038-tubing-fluid-question.html)
miggs78 June 25, 2012 04:12 PM
Trying to decide what to do.. Please poll.. :thumb:
UV Red tubing + distilled water and killcoil or biocide
or
Clear tubing + UV Red fluid
Adzsask June 25, 2012 05:44 PM
Distilled + kill coil is the only thing I use, no problems yet.
gingerbee June 25, 2012 05:58 PM
i have found uv fluid doesn't last all that long where the other route last a very long time
BigPhatPaulie June 25, 2012 06:06 PM
That and the UV fluids are notorious for leaving more residue aren't they?
Overclocking.ca June 25, 2012 06:07 PM
I would also do the red tubing and distilled water route. That's what I plan on doing.
gingerbee June 25, 2012 06:32 PM
yup i aslo found that the uv fluid evap's faster :thumb:
lowfat June 25, 2012 09:18 PM
Option C. Black tubing w/ black sleeving. :biggrin:
miggs78 June 25, 2012 10:23 PM
I was going to edit the poll... don't seem like I can though..
Was going to include Black tubing with distilled water...What fluid with the black tubing?
gingerbee June 25, 2012 10:28 PM
dis-water or option 4 white tubing and dis-water XD
miggs78 June 25, 2012 10:51 PM
Was considering that too ^^ .. Say if I decide to get the NZXT Switch 810 white ver.. then it'll be black tubing or red.. too much white won't look too good.. we'll see, depends on stock too..
