Old June 24, 2012, 08:54 AM
JD JD is offline
Default Heakiller 3.0 LGA1366 works with LGA2011?
I see this exists: Watercool HEATKILLER CPU 3.0 Series 1366/2011 Conversion Kit Products Model: 14076 [14076] : Performance-PCs.com, ... sleeve it and they will come but honestly, it looks the same as the pieces I got with the block. Although my block was only for 1366, well before 2011 was ever announced.
Do you think the stock screws will thread into the LGA2011 backplate? Or should I "waste" $20 just to be safe?
Old June 24, 2012, 10:00 AM
BigPhatPaulie's Avatar
I would be safe. I mean its only 20 bucks plus shipping so it can't hurt to have a little insurance
FOR PONY..... that is alll
Old June 24, 2012, 10:08 AM
lowfat's Avatar
The stock LGA2011 backplate is an M4 thread. LGA1366 mount will work if it is an M4 thread more than likely.
Mael
Big Lian Li
Forever Alone
Old June 24, 2012, 10:12 AM
JD JD is offline
The HK backplate I bought says it's M4 threaded, so I think the studs should just screw into the stock 2011 backplate.
Old June 25, 2012, 09:13 AM
SugarJ's Avatar
To convert a Heatkiller LGA1366 to LGA2011, all you need is this: Aquatuning -Your watercooling and modding distributor - Watercool Umrstkit HEATKILLER CPU 3.0-Serie 1366 auf 2011 16201
I bought the kit. It works. It's 4 longer screws. Same diameter. Or buy some M4 screws locally and save the shipping.
LGA155 or LGA2011 Lucasrivers New Builds 11 March 8, 2012 08:22 PM
LGA2011 heatsinks lowfat Air Cooling 9 January 11, 2012 10:44 AM
LGA2011 Luther CPU's and Motherboards 3 December 20, 2011 05:22 PM
LGA2011 cpu prices. yycraven CPU's and Motherboards 18 November 12, 2011 12:32 PM
z68 or LGA2011? Epimetheus New Builds 5 February 28, 2011 12:57 AM
