Originally Posted by Primu$ Hey,
I would recommend ALWAYS using plumbers PTFE tape its just an extra precaution, weather or not ur setup is tight (to your eye).
Try using some plumbers tape and see if it stops the leak and if you can, do you see any manufacturings defects like crack or breaks in the metal. If so I'd contact them for an RMA if possible.
Primu$ |
NEVER use teflon tape in a watercooling system AT ALL.
Get that train of thought gone and over with.
The barbs and o-rings are designed in such that the o-ring gives a perfect seal. You put teflon tape onto your threads and your going to introduce crap into your system you don't want.
If a barb is leaking with an o-ring either the threads are fubarred, the o-ring was crushed or you didn't tighten enough.
