Old June 22, 2012, 04:53 AM
JD JD is offline
Default i7 920/GTX580 - Minimum Radiator
Since I'm feeling like upgrading (for no real reason) and in turn handing down my system to my brother, what would you guys say the minimum radiator size would be to run a i7 920 and GTX580 adequately? I mean, it doesn't need to be super low temperatures or anything, but just cool enough so they can both operate within their limits.
I was hoping for a single 120mm, but I'm guessing that won't be enough? What about a single 180mm? Trying to keep it internally housed within the Silverstone FT01.
Old June 22, 2012, 04:55 AM
Arinoth's Avatar
Overclocking either of them, also is the i7 920 a C0/C1 or a D0?
Here I am: here I remain
Old June 22, 2012, 05:01 AM
JD JD is offline
It's a D0. Probably have the CPU OC'd a bit, likely not the current 4.2GHz it's at, maybe 3.4GHz or something with HT enabled.
GTX580 will remain stock, it doesn't clock all that great anyhow.
Old June 22, 2012, 05:07 AM
supaflyx3's Avatar
a 240 rad would suffice, but it might a bit toasty. if you can throw a 240+120 in, or a 360 if you have room.
Old June 22, 2012, 08:17 AM
JD JD is offline
Well I mean, anything can hang off the back, but I was trying to keep it internal.
I think I might start with a 180mm up front and if it's not enough, add a 120mm to the rear.
Old June 22, 2012, 08:22 AM
ZZLEE's Avatar
Phobya Xtreme 200mm Radiator (Silverstone / Cooler Master / Yate Loon) - FrozenCPU.com
look at this maybe ?
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old June 22, 2012, 09:36 AM
"Quote This..."
I ran a 240mm with a 920 and 2-gtx260's. All 3 overvolted and clocked to max stable. No problems at all.
Old June 22, 2012, 01:44 PM
JD JD is offline
Was looking at this: Magicool Extreme 180mm x 35mm Slim Radiator (MC-RADI180) - FrozenCPU.com and mounting it to the front 180mm fan and removing the HDD cages.
I think it should be enough surface area to keep things adequately cooled. Machine sits on the floor too so in theory it would get cold air to it.
Old June 22, 2012, 02:35 PM
ZZLEE's Avatar
^ costs less and its native 180
the phobya has a 180 adaptwer plate thogh fore one side and another plate that can get modded to fit anouther fan on the other side.
[WTB] TFX PSU 300w Minimum maverick_brent Buy/Sell & Trade 5 December 23, 2011 04:04 AM
Minimum Specs for Folding? Slaughter HardwareCanucks F@H Team 32 April 11, 2011 12:11 PM
Core i7 minimum entry cost! Lithotech New Builds 57 May 1, 2009 02:33 PM
9600gt minimum powersupply kyle_L Video Cards 4 March 6, 2009 12:44 PM
Minimum Watts for CrossFireX e_1337 Power Supplies 10 March 22, 2008 10:59 AM
