Old June 21, 2012, 03:50 PM
Bungwirez's Avatar
Default Fancy Coolants
Couple of questions.
1) Has anyone experienced the Mayhem Aurora coolant? How long does the fancy last? Are there ill effects to blocks/pumps if using this coolant?
2) If the coolant volume of my rig is greater than the supplied bottle of Dragon Ice, can I just top it up with distilled H2O?
thanks.
I'm Bungz. mostly I bung things up. sometimes I play a doctor on TV.
Old June 21, 2012, 05:30 PM
BigPhatPaulie's Avatar
#1 I dont know
#2 no..... on dazmodes site they say absolutely no water in the loop if possible
FOR PONY..... that is alll
Old June 21, 2012, 07:11 PM
lowfat's Avatar
You can dilute IDC fluid from my testings. But don't do too much. It will start to look diluted, similar to how the Mayhems pastel white looks.
Mael
Big Lian Li
Forever Alone
Need something novel or fancy for a 3.5" bay clone63 Peripherals 21 July 23, 2009 06:01 PM
Chieftec Dragon - nothing fancy 999Virus999 Case Mods, Worklog & Gallery 8 January 17, 2008 05:44 PM
