Old June 19, 2012, 08:28 AM
Default Corsair H60.. will my case fan fit the rad?
Looking at the H60 OEM that is on sale for 49.99 at NCIX right now but am told it doesn't come with a fan. I have a 600T case. Can anyone confirm the black rear fan that came with the case will work just fine? It looks like the same fan just wanted to make sure before pulling the trigger.
Thanks.
Old June 19, 2012, 08:39 AM
SugarJ's Avatar
It should bolt on, but you may want to get a fan with more static pressure to push the air through the radiator.
Old June 19, 2012, 09:16 AM
I might as well get one regular packaging with the fan included, I heard it works really well.
Old June 19, 2012, 09:35 AM
Pabz0r545's Avatar
The fan works ok. It is just that it is quite loud. Won't be any louder then your graphics card though.
Old June 19, 2012, 05:18 PM
Nothing can be louder than the stock am3 cooling fan.
Wicked Corsair 600T Case Mnpctech Cases 6 July 14, 2012 03:21 PM
Corsair A70 and Corsair 600T case Chasingu Air Cooling 3 May 1, 2012 03:37 PM
ITX Case Build With Corsair H60 Possible? kingnubian Cases 9 October 22, 2011 07:52 AM
Corsair's new case accessories... Grampa Cases 4 February 12, 2011 09:35 PM
Corsair Compu Case martin_metal_88 Cases 21 June 16, 2009 07:10 PM
