Old June 19, 2012, 05:10 AM
Default Pump questions with new build
I am putting together a new loop and I am trying to sort out wether I will need to add a 2nd pump to what I already have.
Current loop consists of
Koolance 401X2 --> DDC 3.25 18W Pump --> XSPC EX240 --> Raystorm --> EK RIVE chipset block --> EK RIVE VRM block --> Serial EK GPU Blocks --> Phobya 200mm Rad --> back to res
My new loop will go something like this
Koolance 401X2 (or Tube sytle res depends on tube routing) --> DDC 3.25 18W Pump --> Nexxxos UT60 --> Nexxxos UT60 --> Raystorm --> EK RIVE chipset block --> EK RIVE VRM block --> Parallel EK GPU Blocks --> Back to res
Add in multiple 90, 45 degree adapters and some koolanec QDC fittings
Will the single 18w DDC be able to handle the loop?
Cheers,
Chris
Asus Rampage IV Extreme | Intel i7 3930k | Crucial 4x4Gb | OCZ Vertex 3 MaxIOPS 240GB | WD Velociraptor 1TB | AMD R9 290 Crossfire | Win10 Pro 64 | EK Supremecy | 2 x Alphacool XT45 360 | 2x Liang DDC 3.25 | Swiftech Malestorm Res | Case Labs M8 |
Old June 19, 2012, 07:41 AM
dandelioneater's Avatar
I would think that a single pump would be ok to handle that. I ran 2 rads, 3 universal gpu blocks in parallel (with 90 degree fittings), ek supreme cpu block and a res, on that inexspensive ek pump (forget the name). I had more than adequate flow.
Old June 19, 2012, 09:11 AM
Should be no problem, but I'll never trust a single DDC unless I have something to monitor flow rates or temps to shut off in the event of a pump failure (which isn't uncommon with DDC's).
Old June 20, 2012, 12:31 AM
Plug the pump header into your cpu fan header, no motherboards will boot with no fan or pump plugged into the cpu fan header. One pump is all you need for almost any size loop unless you want the reinsurance of two pumps.
Old June 20, 2012, 07:22 PM
Bungwirez's Avatar
I've never plugged anything into my CPU fan header. of course ASUS provide an off (ignore) switch in bios.
I'm Bungz. mostly I bung things up. sometimes I play a doctor on TV.
Old June 25, 2012, 11:59 AM
Zer0's Avatar
All my mobos boot just fine with nothing plugged into the CPU header.
New Build Questions donny25 New Builds 4 March 1, 2010 10:03 AM
i7 build questions cdbusby New Builds 13 February 26, 2010 01:31 PM
Some questions with a new i7 build kretzm New Builds 4 June 23, 2009 02:37 PM
questions about a 5 HD build philmar New Builds 28 March 23, 2009 07:09 AM
A few questions about my new build Matt New Builds 12 December 12, 2008 06:22 PM
