<~----> Radiator Question - Page 3 - Hardware Canucks
  #21 (permalink)
Old June 23, 2012, 01:27 PM
I would go for a thicker rad.. so like rx360, it has more surface for better heat dissapation, and I would also look at adding a second dual rad 2x120mm.. so there's enough surface for cooling. That's one more reason to go for a Switch 810 :p.. ok i'll stop.. That's what I would do personally.
  #22 (permalink)
Old June 23, 2012, 03:00 PM
lowfat's Avatar
Thicker radiators don't do a whole lot better.
360 Radiator Shootout Summary « martinsliquidlab.org
  #23 (permalink)
Old June 23, 2012, 03:11 PM
Adzsask's Avatar
Since when? H50 to H70 temps dropped 12c with same push/pull fans,same setup.
  #24 (permalink)
Old June 23, 2012, 06:47 PM
xbournex's Avatar
Manufacturer Rep
Originally Posted by Overclocking.ca View Post
So there have been some changes being made to the colour scheme so I decided to pick up a BitFenix Shinobi XL and I was wondering if a EX360 in the roof with GT AP-15s would be enough to run the 2700K OCed to 5.0 or 5.2 and two 560Ti @ 900MHz. Or Would I be better to mod the roof and get 3 more GT AP-15s and do push/pull. I really don't want to remove the hard drive cage to mount a separate rad on the floor.
You would need to mod the roof for that one.
You could try the XT360 and no mod needed.
BitFenix Forum Rep @ NCIX.com | Overclock.net | Overclock3D.net | BitFenix.com | Hardwarecanucks.com
LIKE our Facebook page for contests, product launches, support, and more!
  #25 (permalink)
Old June 23, 2012, 07:18 PM
A little off topic, but since I'm not too familiar with the shinobi, is there a clearance issue or thickness issue with the rad?
  #26 (permalink)
Old June 23, 2012, 07:27 PM
matari's Avatar
You are lucky to get a 10c drop transferring from air to true water. There is absolutely no way you had 12c difference by changing your radiator. Something else was wrong.
  #27 (permalink)
Old June 23, 2012, 08:09 PM
Overclocking.ca's Avatar
It's 80mm from the roof to the motherboard. If you use the full 80mm you might have trouble with your 8-pin connector. Also if you wanted to do push and pull, you could cut the plastic support bars out of the roof and it will fit 3 x 120x25mm fans, the mesh will be sitting tight against the fans I believe.
  #28 (permalink)
Old June 24, 2012, 06:54 AM
Thanks... :) so you you're much better off going for a slimmer rad.. Was speaking to Dazmode a few weeks back, he told me that the the XSPC RS version is just a slimmer version of the RX version and they perform pretty similar. So may consider the RS360 with those AP-15 fans! If it was one cpu and one gpu, a triple would work.. but since you'll be clocking the gpu over 5.0ghz, that would be a lot heat, so.. a secondary rad really I would recommend.. I mean it's up to you, you can try a first run with the triple rad, if you find temps satisfactory, then you'll be fine, otherwise add a second 240mm rad and re-do the loop..
  #29 (permalink)
Old June 24, 2012, 07:18 AM
xbournex's Avatar
Manufacturer Rep
Shinobi - there's no room for radiator without modding
Shinobi XL - Tons of space.
  #30 (permalink)
Old June 24, 2012, 08:33 AM
xbournex: If I put a RS or EX 360 rad in the roof with 3 25mm fans underneath the rad, is this going to interfere with the top 5.25 drive bay? I am asking because if I remove the hard drive cages to but a 240 rad in the bottom, I have to figure out a spot to mount my SSD and 3.5" mechanical drive and I plan on using a Koolance dual 5.25 bay res, a DVD drive and a fan controller.
Radiator question miggs78 Water Cooling 13 June 6, 2012 10:23 PM
Radiator Question HumorusPrawn Water Cooling 4 February 7, 2010 01:30 AM
Fan for radiator phil3_66666 Water Cooling 9 April 21, 2009 02:44 PM
Question about Danger Den radiator barb fittings AERo Water Cooling 16 March 31, 2009 11:23 AM
Radiator Question Scart Water Cooling 22 March 12, 2008 01:49 AM
