Old June 19, 2012, 05:00 PM
If you're doing a dual gpu and cou loop.. personally suggest you get a NZXT Switch 810, lot more rad options really
Old June 19, 2012, 05:11 PM
BigPhatPaulie's Avatar
The 810 is like a godsend for multi rad setups because its price is unheard of for the pontential it brings
FOR PONY..... that is alll
Old June 20, 2012, 12:27 PM
Overclocking.ca's Avatar
With the CM Storm Stryker, if I take out the bottom hard drive cage, I can run a XSPC EX240 rad with a push pull setup. I can also run the same setup in the roof with two of the fans on the outside of the case. I have a couple of questions.
1. If I get the Koolance RP-452X2 Rev 2.0 Dual 5.25" Bay Res is it worth it to get two D5 pumps and run a dual loop setup?
2. If I decide to run a dual loop setup does that res have two separate reservoirs? (noobish question I know)
If the RP-452X2 has two separate compartments I was thinking of doing one loop with distilled water and DazMode Protector with Feeser UV Blue tubing and in the other loop Feeser Clear non UV tubing and IceDragonCooling Nono Fluid - White. Any opinions on this idea?
Old June 20, 2012, 12:37 PM
Think about it.. with the Switch 810 you can run an XSPC RX360 and a RX240 at the bottom.. more room for cooling .. think about it
I am no where any good as others for water cooling, but so far I've read that dual pumps usually only helps if one fails, redundancy purposes... but then again, I'm not any good..
Old June 20, 2012, 01:56 PM
I don't mind the NZXT Switch 810, but a lot of people have used it and I was going to try to be different.
Hell I have plans of making a water cooled m-ATX folding rig in a few months.
Old June 20, 2012, 03:39 PM
When do you plan to pick up the Stryker?
I do like the NZXT Switch 810, but it's big man.. I'll see though, I may end up sticking with it..
Old June 20, 2012, 03:42 PM
Prolab's Avatar
Forget having dual loops. Its a mess and complicated.
Just do one single loop (with either 1 pump or 2).
Gaming Rig:
-Caselab STH10, Swiffy MCP35x2, (2) Aphacool UT60 480 rad, HWL GTX 360, Heatkiller IV, i7 5930k @ 4.5 Ghz, 16GB Ripjaws, Asus X99 Deluxe ii, (2) XFX R9 290 w/ XPSC WB, 240 GB Intel 530, 500 GB 850 EVO, (6) 3 TB Tosh HD, EVGA G2 1300 PSU, Win 10 Pro
HTPC Rig:
-G3258 @ 4.0 Ghz, Asrock Z97 Pro 4, Asus 290, 128 GB Crucial M4, (2) 2 TB WD Green, (1) 2 TB Sammy F4, (2) 5 TB Tosh HD, Enthoo Primo, XSPC 480, 240 HWL GTS, Corsair HX620, Win 10 Pro
Old June 20, 2012, 03:59 PM
Not till mid August or September.
  #19 (permalink)
Old June 20, 2012, 04:58 PM
Aaah that's long time, I was going to wait for you, but I'm building mine fairly soon..
  #20 (permalink)
Old June 23, 2012, 12:24 PM
So there have been some changes being made to the colour scheme so I decided to pick up a BitFenix Shinobi XL and I was wondering if a EX360 in the roof with GT AP-15s would be enough to run the 2700K OCed to 5.0 or 5.2 and two 560Ti @ 900MHz. Or Would I be better to mod the roof and get 3 more GT AP-15s and do push/pull. I really don't want to remove the hard drive cage to mount a separate rad on the floor.
Radiator question miggs78 Water Cooling 13 June 6, 2012 10:23 PM
Radiator Question HumorusPrawn Water Cooling 4 February 7, 2010 02:30 AM
Fan for radiator phil3_66666 Water Cooling 9 April 21, 2009 02:44 PM
Question about Danger Den radiator barb fittings AERo Water Cooling 16 March 31, 2009 11:23 AM
Radiator Question Scart Water Cooling 22 March 12, 2008 01:49 AM
