-   -   Full Coverage Waterblock for Non Reference GeForce GTX 560 Ti (http://www.hardwarecanucks.com/forum/water-cooling/54849-full-coverage-waterblock-non-reference-geforce-gtx-560-ti.html)
Overclocking.ca June 17, 2012 07:40 PM
Does anyone know of a full coverage waterblock for a non reference GeForce GTX 560 Ti. The model I have is the Gigabyte GV-N560OC-1GI. I checked EK Waterblocks, XSPC and Danger Den and couldn't find anything.
I'd really like a full coverage waterblock if not then I guess a universal one will have to do.
Here is a pic of the card with the stock heatsink on and off
http://www.coolingconfigurator.com/u...N56GOC-1GI.jpg
http://www.coolingconfigurator.com/u...OC-1GI_PCB.jpg
Thanks.
BigPhatPaulie June 18, 2012 06:53 AM
For a non-reference? Unlikely:sad:. The only non-ref card waterblocks I have seen are the ones EK makes for high end asus cards but if you've checked the three most likely sources then yea.... Could always try koolance though
dandelioneater June 18, 2012 07:30 AM
You may have to go for one of the universal gpu blocks, and then ramsinks for the other circuitry.
Soullessone21 June 18, 2012 09:04 AM
use a Rasa Block and Vram Coolers by Swiftech
Overclocking.ca June 18, 2012 12:42 PM
What about the RayStorm GPU block?
RayStorm GPU Universal Block [285652] - $59.99 : DazMode PC Watercooling Gear, Canadian Best PC Watercooling and Modding Store
Pabz0r545 June 18, 2012 01:00 PM
You could also sell your card here on the BST and get a different card that supports full cover blocks. :thumb:
