-   -   A rad in a Phantom? (http://www.hardwarecanucks.com/forum/water-cooling/54813-rad-phantom.html)
itayassa June 16, 2012 09:24 AM
A rad in a Phantom?
Hallo :P
Listen, Im thinking about geting a WC loop for my rig, and as a normal men the firts rad options was a nice think 360rad of the loop... buy I have seen that whithout pretty hevvy modding you can mount a 360 rad in a Phantom :doh:
So the next optins is a 400mm rad.. phobya xtreme 400mm radiator!
Can it be mounted in a Phatom? is it a good rad?
Thanks! :D
Hhoo and be the way, I have seen a lot of people put a dual fan rad in the bottom of their phantom(instad of 2 HDD cages), do you know whar side is the rad? can you give me like a guide or something that shows how to do it?
