Old June 8, 2012, 05:51 AM
Default best auto fan controlling system
Hi guys/girls I have been trying to find other fan controllers that fit my needs. I currently have a x58 set up running on water, but running my fans on low does not not allow me the temps to overclock to my liking and on high its to loud. So I am in the hunt for a fan controller but I would like to get one that raises and lowers my fans or even turns them off it not needed depending on the temps. I looked at the Aquacomputing Aquaero 5 but I am curious if there are any others out there.
My set up
2x Rx240 rads
(1 rad with push pull with ap-15, other rad with a pair of ap15, then one ap15 for another intake in the back.)
2x mcp355
would like a flow meter and water temp sensor as well.
case is an old cosmos 1000( so no nobs due to door on case front panel)
As always any help would be amazing. thanks
Old June 8, 2012, 08:02 AM
lowfat's Avatar
I wouldn't even consider anything besides the Aquaero. You could get away w/ an LT (w/ heatsink) as long as you aren't going to try to control your pumps. You would likely need to watercool the Aqauero if you plan on doing that.
Old June 8, 2012, 12:40 PM
thanks
controlling temperatures for watercooling mardig88 Water Cooling 7 January 15, 2012 10:50 AM
Filtering & Controlling Home Network MrDiaz Networking 11 May 18, 2011 04:34 AM
Asus M3a79-t controlling fans Jonwall Air Cooling 0 March 27, 2009 04:20 PM
Motherboard fan controlling? chibi_man Troubleshooting 7 July 15, 2008 09:52 PM
DFI Presents Auto Boost System (ABS) Technology MAC Press Releases & Tech News 8 June 14, 2008 07:15 AM
