Old June 7, 2012, 12:18 PM
Overclocking.ca's Avatar
Default Question about Fittings
Can the fittings in this Bay Res/Pump be replaced with compression fittings?
XSPC Dual 5.25 Reservoir for One Laing D5 Single Loop XSPC Dual 5.25” Reservoir for One Laing D5 Single Loop [XSPC-DBSL-1D5] - $58.99 : DazMode PC Watercooling Gear, Canadian Best PC Watercooling and Modding Store
Thanks.
Old June 7, 2012, 12:30 PM
lowfat's Avatar
Any standard G1/4 fitting will work. They are enough apart to room to fit bigger fittings.
Old June 7, 2012, 12:39 PM
Thanks for the info.
Old June 7, 2012, 01:29 PM
sswilson's Avatar
If you're going to use compression fittings on a "plastic" thread use care to ensure that you're not over torquing the barbs when you tighten the compression part onto the tubing.
Old June 7, 2012, 02:00 PM
Thanks for the tip Steve, I am guessing finger tight should suffice.
Old June 7, 2012, 02:11 PM
sswilson's Avatar
Yep fingertight with some form of grip to ensure the best torque (I've got rubber coated mechanics gloves for a good grip) ... the tip is from personal experience.... ;)
Old June 7, 2012, 02:43 PM
I read your worklog and you had some great tips in there. After many years I have decided to dive into water cooling. I do currently have an Antec 920 kit but I want to get my feet wet with a custom loop. I don't think I am going to water cool my graphics card just the 2600K I recently bought.
I will putting this setup in the Corsair Vengeance C70 case.
This is what I was thinking for a setup so far.
RayStorm CPU WaterBlock (Intel)
Slim High Density Dual 120mm Radiator XSPC EX240
XSPC Dual 5.25" Reservoir for One Laing D5 Single Loop
Scythe Gentle Typhoon 1850RPM 59CFM @ 28db Fans
Feser Tube UV Hose - 3/8" ID - 1/2" OD - SKY BLUE/UV Blue
Various Bitspower 3/8"ID - 1/2"OD compression fittings
Fluid: Distilled Water
DazMode Protector
Heatkiller and Fittings MattC Water Cooling 13 July 21, 2011 10:28 AM
Quick question on UV and fittings/tubing Patlabor Water Cooling 7 March 4, 2010 02:14 PM
Need some advice on fittings jtarle Water Cooling 13 December 24, 2009 11:32 AM
Question on SLI Fittings axle182 Water Cooling 10 July 22, 2009 09:09 AM
Question about Danger Den radiator barb fittings AERo Water Cooling 16 March 31, 2009 11:23 AM
