Originally Posted by sswilson Unless the tube res is part of the look you're going for, without a doubt a bay pump/res... it just simplifies everything so much, and makes for a much cleaner install. |
Alright, you guys converted me. Now for an important question.
I am looking at the Koolance RP-985 Single 5.25 Pump/Res. I think this is actually decently priced considered it is a pump,resevoir, display and fan controller.
My question is, which I can't find anywhere; how many fans does it control? Is there a way to hook up 6 fans (push/pull 360 rad) into one fan slot?
If so, I think it's a good bang for the buck and space saver.
