  #31 (permalink)
Old June 5, 2012, 01:56 PM
KaptCrunch's Avatar
with wax paper, smooth it with a popicle stick to flatten it
  #32 (permalink)
Old June 5, 2012, 02:05 PM
Makes perfect sense. Going to check to see if I have a muffin tin and some silicon. Don't think I have either. lol
How long does silicon take to dry?
  #33 (permalink)
Old June 5, 2012, 09:33 PM
AmuseMe's Avatar
Depends how much you are using, as in, how thick. Also depends on what kind.
  #34 (permalink)
Old June 6, 2012, 01:15 AM
Can anyone tell me if this is an ok way to set up my resevoir and pump?
The bottom port on the resevoir will connect to the top port on the pump. Will this work?
By kyle87t at 2012-06-06
  #35 (permalink)
Old June 12, 2012, 12:26 AM
Astaroth's Avatar
Nope, you have your reservoir situated directly above the outlet (up arrow on top port). Your reservoir needs to connect to the inlet (left port) to feed(prime) the pump. Otherwise your loop will be fighting gravity. You will then be puzzled why your pump is running dry as it pushes the water and then it doesn't go any further.
Noctua C14 Vibration unknownmember Troubleshooting 4 August 24, 2011 05:32 AM
silicone for removing case vibration noise ppippus Case Mods, Worklog & Gallery 3 September 12, 2010 02:49 PM
Vibration from Logitec G51 ToXic Audio 2 August 27, 2009 09:54 PM
Where can I buy some rubber strips for anti-vibration inside pc? appplejack Peripherals 5 January 17, 2009 05:23 AM
