  #21 (permalink)
Old June 4, 2012, 09:22 PM
I had mine mounted with heavy duty velcro pads.. you can get a roll at home depot, one side sticks on the case and the other side to the pump, and sandwich the velcro.. it works!
I also agree with the 3M double sided tape.. the heavy duty stuff (tape of gods as it was referred).. just use it to secure ur pump to the case, and it honestly is going no where..
How are you attaching ur res to it to the pump, using a pump top or ?
  #22 (permalink)
Old June 4, 2012, 09:36 PM
The hose will run from the pump to the resevoir which will be directly above it. The resevoir will have a compression fitting and the pump will be clamped.
What's a pump top?
  #23 (permalink)
Old June 4, 2012, 10:02 PM
lowfat's Avatar
Originally Posted by AmuseMe View Post
I'll mention, that the mousepad does work. One of those rubbery soft ones! It helps my Iwaki... A LOT
I think I need a new mouse pad anyways. Plus this Goliathus is so big I could make like 10 of them.
  #24 (permalink)
Old June 5, 2012, 04:34 AM
KaptCrunch's Avatar
if a pump vibrates that much, RMA it for it not designed to be vibrator unless swift cheeze is buying factory seconds
best thing to do is open pump an look at center bearing where the balance holes are and the weights are in the lateral area of ball of the rotor/impeller
  #25 (permalink)
Old June 5, 2012, 04:54 AM
Silicone pads.
Get some muffin tins, or cake tins, or w/e shape will be easiest to cut to spec. Fill said tins with silicone, and let it dry. Cut the material off the silicone after it has hardened then cut the piece of silicone to spec. You can even just affix it to the pump with a zip tie.
  #26 (permalink)
Old June 5, 2012, 06:34 AM
sswilson's Avatar
Originally Posted by Masteroderus View Post
Silicone pads.
I'm really liking this idea... a person could probably use just about any retail calking product as well. Just ensure that you give it enough time to dry.
  #27 (permalink)
Old June 5, 2012, 12:47 PM
Very interesting ideas. I will be heading to Home Depot today to weigh my options.
  #28 (permalink)
Old June 5, 2012, 01:36 PM
KaptCrunch's Avatar
note coat the tins with baby powder so prevent silicone from sticking or use wax paper
  #29 (permalink)
Old June 5, 2012, 01:51 PM
How would I guarantee that the top dries flat?
  #30 (permalink)
Old June 5, 2012, 01:55 PM
SugarJ's Avatar
Silicone pads.
I suspect this is how Petra's makes their gel pads.
Noctua C14 Vibration unknownmember Troubleshooting 4 August 24, 2011 05:32 AM
silicone for removing case vibration noise ppippus Case Mods, Worklog & Gallery 3 September 12, 2010 02:49 PM
Vibration from Logitec G51 ToXic Audio 2 August 27, 2009 09:54 PM
Where can I buy some rubber strips for anti-vibration inside pc? appplejack Peripherals 5 January 17, 2009 05:23 AM
