The scythes are loud and the relatively high frequency makes them seem even worse. My top choices for good noise/volume are gentle typhoons or, if you can stand the colours, noctuas.
For pumps, the 655 and 35X have very similar max/min performance, but the 35X has a much better curve meaning that in the majority of situations it will perform better. However, flowrate vs temperature is not at all a linear function and going from say 10l/m to 20l/m will actually result in a very very small decrease in temps. The 35X has pwm control and is physically smaller, but the 655 is quieter. Both are rated for the same MTBF, but personally I have had way better luck with 655s.
There are probably hundreds of 350/5/X vs 655 threads on the net but swiftech now provides comparison charts of their own to end the debate.
