Old June 4, 2012, 11:23 AM
lowfat's Avatar
Originally Posted by miggs78 View Post
Hey lowfat, even above the D5 pump? But I'll give it to Swiftech to move away from their old housing and come up with 1/4" threads for actual fittings, smart move.. I have a D5, and now you're making me sell that and get the mcp35x and buying a tube res to add to it.. gotta buy a freaking top for this d5
I would go for Primochill tubing over Feser, bend radius and it really is higher quality
If you have the pump already I wouldn't buy something else. Pumps aren't all that important in terms of performance. But I won't buy anything other than the MCP35X from now on. Being able to control my pump w/ Speedfan is really awesome.
As for tubing, I am not a fan of Primochill anymore. They have changed their tubing somehow recently and it plasticizer is a real problem with it. Unfortunately I don't know any other tubing that doesn't have this problem.
Old June 4, 2012, 12:15 PM
Reyzac's Avatar
The Scythe fans cool very well but for me, the noise is intolerable. Great for open-air rigs but in a case? Jets.
Who needs a real doctor when you got my machines and their scary needles?
Old June 4, 2012, 12:33 PM
Adzsask's Avatar
As said above, you get these fans close to mesh and they start howling, I use nothing but scythe Gentle Typhoon AP-14/15 as long as they are made(and long after because they never die). Also colermaster R4's are the best low cost fan, but again very loud next to mesh or rad fins, have to pay for silence :) cougar makes a fan close to a GT AP-15 for a lower cost.
Old June 4, 2012, 01:54 PM
SugarJ's Avatar
I'm another person who's moved from Scythes to Gentle Typhoons. The GT's are half as noisy as the Scythes at the same RPM.
Old June 4, 2012, 02:04 PM
Overclocking.ca's Avatar
Looks like I will probably get the Gentle Typhoons.
Question about reservoirs are the custom FrozenQ Liquid Fusion 250's worth the money for that extra blind with the CCFL and double helix in them?
Old June 4, 2012, 02:15 PM
Adzsask's Avatar
Only worth it if you prefer the look, I myself prefer a res top sitting on the pump.
Old June 4, 2012, 02:44 PM
lowfat's Avatar
FrozenQ has a bad rep when it comes to quality control and even worse customer service.
Old June 4, 2012, 03:59 PM
Would their double helix fit in the EK tube style res?
  #19 (permalink)
Old June 4, 2012, 04:58 PM
Bungwirez's Avatar
I wouldn't waste money on that mod.
take a look a the mayhem aurora fluid if you need bling.
If you don't like funerals, don't kick sand in Ninja's face
  #20 (permalink)
Old June 7, 2012, 02:18 PM
nasrott's Avatar
get a res to fit the pump you buy, Daze has a pretty good assortment of them
[WTB] Scythe Slip Stream Fans r0k0 Buy/Sell & Trade 0 February 13, 2012 01:19 AM
Scythe Slip Stream 140mm Fans Launched Soultribunal Press Releases & Tech News 16 April 16, 2010 09:22 AM
Scythe Slip Stream Kaze Jyuni stormkiller22 Troubleshooting 4 March 8, 2008 02:10 PM
