Old April 4, 2008, 08:08 PM
ChuckleBrother's Avatar
Default Safety Shutoff - GPU
So basically I wanna know if theres a built in and adjustable setting that I can change so my GPU will perform a "Holy Shit" manoever in case it starts getting too hot, and shut off my machine. I know the CPU has one in the BIOS that you can adjust on most motherboards, but I haven't found a thing about the GPU, which will be on the only component cooled by this loop.
Any help is appreciated, google is failing me:(.
"...you play a mean banjo"
Old April 5, 2008, 08:28 AM
lowfat's Avatar
Software, not that I know of. But an mCubed T-Balancer can. Although it is kinda expensive.
Mael
Big Lian Li
Forever Alone
Old April 5, 2008, 08:49 AM
sswilson's Avatar
I'm not sure it's that big of an issue unless you are doing a volt mod on your card. Most cards won't even come close to the upper thermal limit before crashing the system.
Old April 5, 2008, 09:46 AM
My GPU is the only thing that will be on my loop, so if the pump dies or something, my card might burn itself to a cinder:(.
Old April 5, 2008, 10:01 AM
Supergrover's Avatar
Look at Rivatuner's "core temperature" setup options I think that it should be able to do it for you.
Granted I have never tried and dont have the time ATM to do so.
R.I.P.
Old April 5, 2008, 10:45 AM
I'll take a look at that, thanks.
Old April 5, 2008, 10:58 AM
MpG's Avatar
MpG MpG is offline
If you're using a single water pump, many of them (DB-1, MCP-350,MCP-355, etc) come with an rpm output that can be attached a mobo fan header to give a speed signal. Most BIOS's will then let you arrange an auto-shutdown if the "fan" suddenly dies.
Old April 5, 2008, 03:34 PM
lowfat's Avatar
good however other things can happen like a leak happening. My pump was still pumping, just didn't have any water in it Waterblock still melted.
Mael
Big Lian Li
Forever Alone
Old April 6, 2008, 06:40 PM
Supergrover, what version are you using there? Mine seems to be missing that section, I just dled what I THINK is the latest version.
Old April 10, 2008, 12:43 PM
Hey ChuckleBrother,
I used a software called mbm5 (google it) im not sure if its compatible with yours or newer motherboards, but check it out, its similar to the one Supergrover posted. Also your best bet to avoid a situation like that, is by software that lets you control pretty much your pc. Hopefully Supergrover will be able to supply an updated link for the program.
Primu$
Intel P4 2.0Ghz @ 3.5Ghz ON AIR! >> FTW?!
Heatware
