Originally Posted by medwes For the pump I only recommend mcp655 noting else and if you are just cooling 1 CPU, one single GPU (not 2 or sli - Crossfier), the 360 will be more than capable of cooling them but if you planning to add more GPU's you will be better with bigger Rad like 4x120 or 4x140 radiator |
^^^ This
The airplex has more options for routing tubing, but really you are paying waaay more just for it being bare stainless/copper.
The 655/D5 is a bigger, uglier pump, but based on my own experience, it is much quieter and more reliable than a 355 style pump. Either run it as it is or add a pumptop or pump/res combo that makes tubing management easier for you. Be aware that if you are using the pump as is, it comes with non-removable 1/2" barbs. A 360 with some medium speed fans will be the minimum for a single CPU and GPU, but should handle it just fine. XSPC RX rads are great value per dollar and are some of the best performers out there. 1/2" ID x 3/4" OD tubing gets my vote, just make sure you get the right barbs or compression fittings. Barbs are cheaper, compressions are prettier. Neither should leak a drop.
