Old May 12, 2012, 06:46 AM
gingerbee's Avatar
Default water chiller ?
ok well if the offer on are house falls through i will be putting a water chiller in a loop i want to get people opinions here on what one to use and where to get it from for a good price so please lets talk about add a water chiller to your cooling loop
Old May 12, 2012, 09:23 AM
Adzsask's Avatar
If I had money to spare, I would grab myself a nice pre made unit like this one :)
Hailea HC-500A Water Chiller Review | bit-tech.net
Old May 12, 2012, 09:35 AM
lowfat's Avatar
You could make yourself one for about $50. Go to a pawn shop and find an older window air conditioner. Remove casing. Slowly and carefully bend the evaporator piping so you can submerge the evaporator in to some sort of reservoir for your coolant. But honestly I wouldn't bother w/ a chiller. Modern CPUs and GPUs don't scale as well as they use to w/ extreme cold.
Old May 12, 2012, 09:37 AM
Adzsask's Avatar
Originally Posted by lowfat View Post
You could make yourself one for about $50. Go to a pawn shop and find an older window air conditioner. Remove casing. Slowly and carefully bend the condenser piping so you can submerge the condenser in to some sort of reservoir for your coolant. But honestly I wouldn't bother w/ a chiller. Modern CPUs and GPUs don't scale as well as they use to w/ extreme cold.
All the more reason to use a chiller, keep everything at 30C to maximize overclock, without going sub zero.
Old May 12, 2012, 10:14 AM
lowfat's Avatar
It won't gain you any MHz really though. Not w/ Sandy Bridge or most newer videocards. Plus there is the fact that it will be rather loud. In something like a computer the compressor is going to be 24/7. Plus the fans on the condenser are going to be loud.
Old May 12, 2012, 03:19 PM
gingerbee's Avatar
ya but it might allow me to push my 3770k to it's limits i just dont want to pay 1000$ for a water chiller
Old May 12, 2012, 04:18 PM
KaptCrunch's Avatar
your also missing that the chiller will suck alot of hydro and need to freeze protect for most evap coils hit below freeze point another thing is condensation control
Old May 12, 2012, 05:31 PM
gingerbee's Avatar
nope i have thought about all of this i dont pay hydro right now and i am doing subzero with dice now so i am pretty good easier then the dice and a pot
Old May 14, 2012, 05:47 AM
KaptCrunch's Avatar
ah i see early morning dew not a problem with this set-up for Evap does the chilling and condensor exspells heat
gingerbee
you still need to freeze protect and insulate WB's from dew with Hailea HC-500A Water Chiller or AC
best use pet safe anti-freeze mixed for -20c and set-up relays for 1 button starting/run pumps/fans
Old May 14, 2012, 04:17 PM
lowfat's Avatar
gingerbee
You still need to protect against condensation w/ the modified air conditioner. You could see coolant temps below freezing no problem.
Aquarium gear for water cooling??? WATER CHILLER??? clshades Water Cooling 6 March 15, 2012 09:21 PM
226 watt TEC inline chiller BrainEater Water Cooling 52 March 6, 2012 08:28 PM
Adjustable Liquid Chiller by NoL NoL Case Mods, Worklog & Gallery 5 March 27, 2008 06:59 AM
Tec water chiller using Apogee gt's kirk_d Water Cooling 1 February 25, 2008 12:36 PM
AC Water Chiller project sizerkozak CPU's and Motherboards 27 March 13, 2007 06:26 AM
