-   -   Will One Pump Suffice? (http://www.hardwarecanucks.com/forum/water-cooling/54176-will-one-pump-suffice.html)
bkh2 May 11, 2012 09:09 PM
Hi, I'm looking to run a Swiftech XT CPU block, EK Northbridge block, a universal GPU block (AquaXtreme MP-1), and three Swiftech triple rads. Do you think a single Swiftech MCP655 will suffice? It's the one with a speed adjuster, if that makes any difference.
Bungwirez May 11, 2012 09:49 PM
Interesting question. the three rads bit is what IDK. otherwise I would vote no issues.
what is preventing you from going dual pump for safety sake?
bkh2 May 11, 2012 10:56 PM
A combination of cost and space constraints. Is three rads too many? I suppose I could just use two. I just have three lying around so I thought I'd use them all.
Bungwirez May 12, 2012 06:31 AM
go for it then.
lying around parts need to be put to use.
Adzsask May 12, 2012 09:29 AM
One pump is fine, most people with two pumps could easily use one, but choose two for redundancy, I am cheap/poor so I run a single pump, and just set my motherboard to shut down if my CPU reaches 65C.
