Old May 9, 2012, 07:00 AM
BigPhatPaulie's Avatar
Default Fan Question
Hey guys what would be the best fan for pulling air through a rad? Reason I ask Is i have a xspc rad mounted in the top of my case (240mm) and the fans have to be mounted so that they pull air through it from inside the case and out the top.
Case is a corsair 600T white btw
Cheers
Old May 9, 2012, 08:04 AM
Keltron 3030's Avatar
Scythe Gentle Typhoons - Scythe Gentle Typhoon 1850RPM 59CFM @ 28db Fan Scythe Gentle Typhoon 1850RPM 59CFM @ 28db Fan [D1225C12B5AP-15] - $22.99 : DazMode PC Watercooling Gear, Canadian Best PC Watercooling and Modding Store
FFFFFFFUUUUUUUUUUUU-
Old May 9, 2012, 08:06 AM
stoanee's Avatar
Scythe Gentle Typhoon 1850 rpm is a good fan.
http://http://ncix.com/products/?sku...facture=Scythe
Ha, ninja'd!
heatware
Old May 9, 2012, 08:52 AM
Wow quick replies this is a great forum! Thanks guys I had read a few times that they were but figured I would ask if it fit the application I wanted. Thanks again
Old May 14, 2012, 07:32 PM
So I've got the fans (great product) and they are great, move a lot of air etc but I have another question. Running a 990fx Ud5 mobo and running the fans off of that at 100% yet cpu HWmonitor says they are running at 1750 instead of the rated 1850. Does the extra 100rpm really matter or are they too much for a mobo to run?
FOR PONY..... that is alll
