Old April 3, 2008, 12:47 PM
lowfat's Avatar
Default Ever seen a melted waterblock before? *PICS*
For those who don't attend the XS.org W/C forum here are some pics of my DTEK Fuzion GFX.
Old April 3, 2008, 01:20 PM
3.0charlie's Avatar
Ok. I have to ask.
What did you do.
Old April 3, 2008, 01:37 PM
Cptn Vortex's Avatar
Yeah. How the heck do you do that....
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old April 3, 2008, 01:39 PM
Babrbarossa's Avatar
HoW?
psst, wanna see my binder?
Old April 3, 2008, 02:15 PM
magictorch's Avatar
is that some kind of chemical reaction, its difficult to melt copper?
Old April 3, 2008, 02:17 PM
Eldonko's Avatar
Hardware Canucks Reviewer
????? What did you try and cool with that, your car?
Old April 3, 2008, 02:47 PM
Wankerfx's Avatar
Did you try to cool a TEC, or did your pump fail while your PC was on?
[ER]
Old April 3, 2008, 03:23 PM
werty316's Avatar
DAMNNNN!!!!!!! I've never seen one that bad.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old April 3, 2008, 03:46 PM
lowfat's Avatar
That was on an 8800GT :) I think a leak sprung elsewhere in the loop. I don't know how long the waterblock was without water since when I awoke the computer was off and the motherboard dead. It is hard to believe but the videocard survived this :) And so did the pump which is odd as it was running dry as long as the computer was still on.
Old April 3, 2008, 03:50 PM
Aww scary!!!! Where did it leak from?
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
