Old November 24, 2006, 12:06 AM
Misoprostol
Guest
Posts: n/a
Default Anyone looking for help with a water cooling setup, please post here
Hey guys, I'm just extending a hand to anyone who wants to set up a water cooling setup. In this thread you can ask for component advice, how to set up your system inside your case, or just post a really cool water cooling project that you've undertaken (or completed). I'll do my best to answer, as will the rest of the members of our community. I should be able to get some pics of my own setup in here in the next couple days :)
Old January 4, 2007, 07:31 AM
sizerkozak's Avatar
Heres mine
QX6700
ASUS P5N32-E SLI
BFG 8800 GTX
OCZ DC 2048MB PC8500 1066MHz DDR2 SLI
RaptorX 150GB 10K RPM
Three LGL1919S & 3HeadToGo
BFG 1000w
-20C Liquid Chiller
Rig Pics and Stats
Water chiller project
Monitor mod
Old January 4, 2007, 07:59 AM
Babrbarossa's Avatar
I know nothing about liquid cooling and I have an antec p180 case- Is there a good cooling system that I could house inside my case? I don't necessarily need to cool the ram or 8800gts (I don't think) unless removing the arctic cooler would cause things to warm up in there for my vgu.
Main: ASUS P6TD Deluxe// i7 920// XFX HD 7970// 6GB GSkill Trident 2000// Corsair HX1000// Temjin TJ-07// OCZ Vertex2 240GB// GSkill Titan 256 SSD//Kingston SDnow 120GB// Logitech G9 //X-Fi Prelude//Merc Stealth//
Cooling: Coolit Boreas 12 MTEC// HK copper v.3//EK multi 150 res// Swiftech mcp355//EK nickel WB
Screen: Samsung 27" 850D
Old January 4, 2007, 11:30 AM
sizerkozak's Avatar
Originally Posted by y eye View Post
What is the control panel in the 5.25? How is it connected? It looks like it may control four fans + .
y
Lets see...
It controls all the fans, the lights and the pump.
I hated all the stupid conectors you would have laying around the case so i chooped them all off and wired everything directly into the control panel...it distributs the power out from there.This way i can dim the lights and lower & raise the fan speeds as i need to.
QX6700
ASUS P5N32-E SLI
BFG 8800 GTX
BFG 1000w
-20C Liquid Chiller
Rig Pics and Stats
Monitor mod
Old January 4, 2007, 12:31 PM
sizerkozak's Avatar
04jan07
What is the make and model of the controller?
y
Zalman 6-Channel Fan Speed Controller
http://www.tigerdirect.ca/applicatio...2913&CatId=501
QX6700
ASUS P5N32-E SLI
BFG 8800 GTX
BFG 1000w
-20C Liquid Chiller
Rig Pics and Stats
Monitor mod
Old January 4, 2007, 06:28 PM
Supergrover's Avatar
Doh, looks @ case thinking:D
Only thing that makes me leery of that fan controller is this
"Maximum Power: 7.0W per channel "
Maybe it's just me but thats to low. But I have had Tornado's so............
What are the analog gauges on the front for?
I love analog gauges myself, got a CM Musketeer II that has 3 gauges 1 for hdd speed 2 for left/right audio output.
R.I.P.
Old January 4, 2007, 08:34 PM
sswilson's Avatar
Does it need to be inside the case, or would it be acceptable to have a rad mounted on the back?
Airflow inside the case is an important (often overlooked) part of any water cooling setup. It's no use cooling your cpu down to ambient if your chipset temps end up going through the roof.
I'm certainly not an expert (look at the mangled job I did of mine.... :) ) but I have had a pretty good look around at the different kits available so if you can come up with a price range I can point you towards what I've seen.
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
Old January 4, 2007, 09:37 PM
I saw a picture of the rear mounted rad today and I'd be happy with that. If I could get good working, durable cooling for under 150, I'd be happy, but I really don't know what to expect to pay.
-Thanks
Old January 5, 2007, 07:30 AM
Thanks- I wonder if those 8800gtx coolers work on the gts.
It would appear that 200 bucks is pretty much the starting point to H2O,
I'm not sure if I'm thinking along the right lines, but I think I would rather have the radiator and pump seperate, so that in a couple of years I can replace the pump w/o replacing the rest of the kit.
I like the look of this kit-- any good?
http://www.ncix.com/products/index.p...cture=Swiftech
Old January 5, 2007, 08:56 AM
sizerkozak's Avatar
I dont know much about kits ...but thru my research i found that most people prefer to build there own kits piece by piece and always go with seperate components so that upgrading and replacements arent a hassel.
Thats why i bought the kit that i did....so that i can change things as needed.
Ive seen lots of kits that have the rads mounted in the rear both inside and out ( just reverse the fans if needed)...thats why i put one rad in and one rad out...
Just my 2cents worth
QX6700
ASUS P5N32-E SLI
BFG 8800 GTX
BFG 1000w
-20C Liquid Chiller
Rig Pics and Stats
Monitor mod
Water Cooling Setup Overview Sting3r11 Water Cooling 10 November 28, 2007 09:52 PM
First water cooling setup. jubeix Water Cooling 6 November 16, 2007 07:22 PM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 10:22 PM
My new, long awaited water cooling setup! Wankerfx Water Cooling 12 September 5, 2007 09:44 PM
Another DIY Water Cooling Rig Magnesious Water Cooling 5 April 14, 2007 12:51 PM
