  #71 (permalink)
Old July 13, 2007, 03:19 PM
Somed00d's Avatar
Originally Posted by Misoprostol View Post
Antec 900 is a pretty horrible water cooling case...
Also, how are you planning to make your own pump? PC Water cooling pumps are quite inexpensive...
Where are you reading 42C with air? Is that load temps?
i was thinking of getting an antec 900 for watercooling (rad in the front..) what perticularly is bad about it?? any case suggestions for a 2x120mm internal rad around $100
Q6600 G0 @ 3.2ghz (965 chipset holding me back)
DFI Infinity P965-S
Gigabyte Geforce 8500GT
Buffalo Firestix FSX800D2C-K2G 2X1GB PC2-6400 CL5
OCZ XTC Active Memory Cooler
Seagate Barracuda 250GB SATA2
MCE Wireless Keyboard / Remote
Logitech X-530 Speakers
Swiftech H20-220 Water kit
Swiftech MCW30 NB Cooling
OCZ PowerStream 600W
  #72 (permalink)
Old July 13, 2007, 03:44 PM
Patriote's Avatar
You won't get any "decent" watercooling case for 100$ m8. Sorry!
But yeah... Any case around that price range can house watercooling stuff...If modded. If you think you have some skills with a jigsaw and\or dremel, maybe you could get some cheap case and mod the hell out of it to make all your watercooling stuff fit in it. But it'll be a pain to keep everything internal.
- Asus P8Z68-V PRO
- Intel I5 2500k @ 4.5Ghz
- Asus Geforce 580GTX DirectCUII Fermi
- 16GB Corsair Vengeance Low Profile
- Ultra X3 1000 Watt
- Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
- Corsair Vengeance 1300 Gaming Headset
- Crucial M4 SSD 128GB \ WD Caviar Black 1TB
- CoolerMaster 690II Advanced
- Dell UltraSharp 24''
- Noctua NH-D14
  #73 (permalink)
Old July 13, 2007, 04:22 PM
Somed00d's Avatar
i got the skillz.. i work in an auto stampings plant.. lots of metal at my fingertips.. perhaps i will make something wild from scratch..
DFI Infinity P965-S
  #74 (permalink)
Old July 13, 2007, 04:31 PM
Patriote's Avatar
Custom FTW! I'd like to see this
- Asus P8Z68-V PRO
- Noctua NH-D14
  #75 (permalink)
Old July 13, 2007, 07:31 PM
reaverclan's Avatar
yes those are load temps, and for a pump a fish tank one, then weld together box for it. Then u add water and have a water tight gasket with wire for power coming out ( similar to this
The Reservoir and Pump
Not all systems need a reservoir, however it is easier to maintain your system if you do have one. If you like, you can buy a pre-made reservoir. The websites listed under the Waterblock information all carry them. The alternative to pre-made, is to build one yourself. They are very easy and cheap to make, so we will show you how. You can pick up all the materials at Home Depot, and here is what you will need:
QUANTITY - DESCRIPTION (Click any description for an example photo)
1 - 6"x6"x4" Electrical junction box
1 - 3/8" male brass hose barbs
2 - 3/8" femal brass hose barbs
1 - Submersible fountain pump (with atleast a 100gph rating!)
1 - Roll of teflon tape
1 - Tube of silicone sealant
1 - Short piece of 3/8" ID tube a few inches in length
1 - Roll of electrical tape
2 - Small hose clamps
1 - Gallon of distilled water (under a dollar at any grocery store - no picture)
cherrs
rvc
edit: probably wont actually put in case till later just want experince and it will give me something to do when young ones are at summer camp.
  #76 (permalink)
Old September 17, 2007, 11:09 AM
Supergrover's Avatar
Internal vs External Rad setup
Okay looking at my Tt Armour case I had wanted to put my rad hright up at the front, the problem i have is I run 2 I-cages, it's a metal hdd cage that has a 120mm fan atached to it, but if I leave these in I will see the rad and fans.
As you can see the whole rad+ fans will be very visable, I dont want that, while seeing part of the rad would be fine the whole thing is to much IMO.
So what are the differences between a internal mount and doing a radbox?
If I do do ( I said DO-DO ) a radbox what is the maximum distance I want between these?
This thread is my parts thread.
http://www.hardwarecanucks.com/cooli...ld-thread.html
R.I.P.
Water Cooling Setup Overview Sting3r11 Water Cooling 10 November 28, 2007 09:52 PM
First water cooling setup. jubeix Water Cooling 6 November 16, 2007 07:22 PM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 10:22 PM
My new, long awaited water cooling setup! Wankerfx Water Cooling 12 September 5, 2007 08:44 PM
Another DIY Water Cooling Rig Magnesious Water Cooling 5 April 14, 2007 11:51 AM
