  #61 (permalink)
Old July 11, 2007, 02:12 PM
Misoprostol
Guest
Posts: n/a
Don't forget your radiator in that planned loop order.
The only time the order of your loop makes a difference is when you're using a t-line. Your loop will bleed exactly the same with a reservoir regardless of how you set it up.
Shrouds are good, but their impact on performance is minimal. Dont' worry about it.
The rad can be higher than the reservoir without causing any problems.
  #62 (permalink)
Old July 11, 2007, 02:22 PM
Somed00d's Avatar
lol yeah that would be a big problem if i actually forgot that.
ok.. here is what i plan
pump -> cpu block -> chipset -> rad -> res -> pump
thanks for the insight.
  #63 (permalink)
Old July 11, 2007, 03:04 PM
3.0charlie's Avatar
Nope, not quite. It's:
pump - rad - cpu - chipset - res - back to pump.
You want to have the "coldest" water to cool the CPU as much as possible. What's your case?
John
  #64 (permalink)
Old July 11, 2007, 05:13 PM
Somed00d's Avatar
the case is a canada computers house brand.. just like this one:
Canada Computers - Cases > Clearance : Duke P4 ATX Mid Tower Case with 450w PS (White-Silver) FC-DU09AL-WE/SV.
but black.. has 3x120mm fans (1xfront 1xrear 1xleft side) and a 80mm fan mount on the right side to cool the drives. not a bad case for $40..
i may mod the top of the case for the rad or upgrade to an antec 900 and put it in the front...
  #65 (permalink)
Old July 12, 2007, 09:53 PM
reaverclan's Avatar
Smile hey got an antec 900 and need advice
to keep it short antec 900 case wonding what tubing would be best im going to make my own pump buy rad and only need cpu buy tubbing at home deopt or something lol, im in usa btw. so will this cluterd case fit 1/2 id tubing i doubt it but eh im asking experts. heres my link to my comp so far reaverclan/comp log/c2d setup - Photobucket - Video and Image Hosting or do i even need water i have awsome temps right now
like 42c at load with air.
edit: heres temps pic that when running like four games all at max including Oblivion maxed out with out artifacts:) OHNOHEDIDNT.jpg - Image - Photobucket - Video and Image Hosting
cherrs and thanks for the help
  #66 (permalink)
Old July 12, 2007, 10:54 PM
Patriote's Avatar
First first, could we get your computers specs ?
Second, why do you want to get watercooling ?
Third, are those temps with an overclocked CPU or GPU ?
Normally, ppls get watercooling to push their watercooling further. Now, i do realize that some will get it for the "bling" factor and only for that... But if thats why your aiming at watercooling, then, IMO, it's useless to go watercooling.
Oh and BTW: Your English is terrible. Had a hard time understanding you Kinda hard to help when you can't understand the questions!
- Asus P8Z68-V PRO
- Intel I5 2500k @ 4.5Ghz
- Asus Geforce 580GTX DirectCUII Fermi
- 16GB Corsair Vengeance Low Profile
- Ultra X3 1000 Watt
- Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
- Corsair Vengeance 1300 Gaming Headset
- Crucial M4 SSD 128GB \ WD Caviar Black 1TB
- CoolerMaster 690II Advanced
- Dell UltraSharp 24''
- Noctua NH-D14
  #67 (permalink)
Old July 13, 2007, 10:38 AM
reaverclan's Avatar
Post
oh sorry about my English it was 5 in the morning when i made that and, my grammar sucks i know(sorry) anyway umm specs... antec900, Asrock dual4coreVSTA, e6420@2.3grz, x1950pro 512mb's, x-fi extreme gamer i think, corsair 620 psu, 2gb's kingston ddr2 (cpu z 1.39 says its at 677 mrz 3-3-3-3, but cpu-z 1.40 says 210mrz 3-3-3-3 which is probally whats its at).
  #68 (permalink)
Old July 13, 2007, 10:50 AM
sswilson's Avatar
If the board is setting it as 3-3-3-3, I can almost guarantee that it's running at the 210 speeds. That's not all that bad though, you're probably getting some mighty fine bandwidth with your latencies set so low.
  #69 (permalink)
Old July 13, 2007, 02:32 PM
Patriote's Avatar
Bah, seriously m8, i don't think you need watercooling. And that 900 case is one of the worst case out there for watercooling. But if you really want to get watercooling, i'll help you out for sure!
- Asus P8Z68-V PRO
- Noctua NH-D14
  #70 (permalink)
Old July 13, 2007, 02:52 PM
Misoprostol
Guest
Posts: n/a
Antec 900 is a pretty horrible water cooling case...
Also, how are you planning to make your own pump? PC Water cooling pumps are quite inexpensive...
Where are you reading 42C with air? Is that load temps?
Water Cooling Setup Overview Sting3r11 Water Cooling 10 November 28, 2007 09:52 PM
First water cooling setup. jubeix Water Cooling 6 November 16, 2007 07:22 PM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 10:22 PM
My new, long awaited water cooling setup! Wankerfx Water Cooling 12 September 5, 2007 08:44 PM
Another DIY Water Cooling Rig Magnesious Water Cooling 5 April 14, 2007 11:51 AM
