  #31 (permalink)
Old February 24, 2007, 12:07 PM
cdn_Madrach's Avatar
Ok thanks I appreciate the help.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
  #32 (permalink)
Old February 25, 2007, 12:18 AM
Misoprostol
Guest
Posts: n/a
No problem :)
  #33 (permalink)
Old February 25, 2007, 04:06 PM
sswilson's Avatar
Unhappy Water Cooling gone bad
Heh.....
Need a bit of help pulling my hair out......
My Waterblock cracked over the weekend while I was away.
Don't think the cpu fried.... it will post and the HD runs (No vid though).
Not sure on the vid card though.... the fluid leaked right onto it, and there was no video when I got to the computer....
Gonna clean the card off at work tomorrow and check it out.
I'd seen a little bit of fluid on the bottom of the case last week, but I couldn't find a leak and it looked like it was probably just a little bit of spill from the last time I filled it so I let it go.
Don't know if they'll replace the water block or not. Find out tomorrow.
  #34 (permalink)
Old February 26, 2007, 06:15 AM
Babrbarossa's Avatar
Unbelievable! how the heck does a waterblock crack -- my condolances, sswilson.
psst, wanna see my binder?
  #35 (permalink)
Old February 26, 2007, 06:29 AM
Could be a flaw in the block itself or possibly too much torque on it. I have a big water installed in a system and no problems so far, but I know of at least two people that have had their Tt cpu block crack and in both cases fried the video card. Hope you have better luck than them. In one case the pci-e slot also fried. I kinda got worried when that happened so I looked into what should be done in case of a leak. They say that after the affected parts are dry you should thoroughly clean them with electronic parts cleaner or alcohol and dry again. Just my 2 cents, I hope all is not lost. Good luck.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
  #36 (permalink)
Old February 26, 2007, 06:47 AM
So I wonder if it's a problem that is endemic to T.T.-- anyone heard of any other blocks cracking?
  #37 (permalink)
Old February 26, 2007, 08:07 AM
Misoprostol
Guest
Posts: n/a
Danger Den used to use a lower quality acrylic and suffered from some cracking problems at one point, but that issue has since been taken care of. AFAIK, Thermaltake is the only company whose blocks are still cracking.
  #38 (permalink)
Old February 26, 2007, 10:01 AM
I think it is because Tt's blocks are mounted by a metal H bracket that only covers a strip in the middle where all the pressure is probably concentrated rather than like most other blocks where the pressure is more evenly distributed. Or it's a quality issue or both. More 2 cents.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
  #39 (permalink)
Old February 26, 2007, 10:10 AM
Are they aluminum, rather than copper?
  #40 (permalink)
Old February 26, 2007, 10:29 AM
Copper with a clear acrylic top.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
Water Cooling Setup Overview Sting3r11 Water Cooling 10 November 28, 2007 08:52 PM
First water cooling setup. jubeix Water Cooling 6 November 16, 2007 06:22 PM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 09:22 PM
My new, long awaited water cooling setup! Wankerfx Water Cooling 12 September 5, 2007 08:44 PM
Another DIY Water Cooling Rig Magnesious Water Cooling 5 April 14, 2007 11:51 AM
