  #21 (permalink)
Old February 11, 2007, 01:21 PM
The fridge will remain fully functional for my beer cooler as well as double as CPU and NB cooler. Should be interesting. I will try to post diagrams soon. I don't even know how efficient this rig will be.
  #22 (permalink)
Old February 11, 2007, 01:38 PM
Please Google the idea and read up on the idea before spending any money :) I thought about the small fridge idea about a year ago and can't recall exactly the technical reasons why but the idea didn't come out as favorable.
Here is a link to just a small start on the subject http://www.overclock.net/faqs/105345...pc-cooler.html
  #23 (permalink)
Old February 11, 2007, 02:30 PM
OMG. I can't believe someone would actually place their pc in a fridge or freezer. No wonder it won't work. there is no way a fridge can remove that amount of heat. cpu, gpu, nb, sb, hd, psu etc... I was thinking more along the lines of using the fridge to chill the coolant. Place a 2-3 litre reservoir of coolant in the fridge, coil the lines on the inside of the fridge wall, then pipe it to the cpu. Does that sound feasible?
  #24 (permalink)
Old February 14, 2007, 11:20 PM
Misoprostol
Guest
Posts: n/a
No it's not feasable. A CPU outputs as much as 150-200 watts. Fridges are not designed for constant heat load, but rather intermittent operation. Your compressor would burn out in no time.
  #25 (permalink)
Old February 18, 2007, 05:32 PM
cdn_Madrach's Avatar
Just curious whether or not the thermal compound that comes with swiftech water blocks is good or would it be better to use arctic silver, reg or ceramic?
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
  #26 (permalink)
Old February 19, 2007, 08:09 AM
Misoprostol
Guest
Posts: n/a
The goop that comes with Swiftech (and Danger Den for that matter) blocks is Ceramique.
  #27 (permalink)
Old February 22, 2007, 06:45 PM
Thanks. I do have another question for you. I read your review of cpu water blocks and noticed you used one set of barbs and was wondering if they were danger den chrome ones? I have all swiftech blocks and read that some barbs won't fit correctly. I would like to use chrome barbs but cant seem to find swiftech ones. Will the danger den ones work?
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
  #28 (permalink)
Old February 23, 2007, 11:00 AM
Misoprostol
Guest
Posts: n/a
yeah they were Danger Den perfect seal barbs. In my experience G1/4 barbs work just fine in Swiftech blocks. Just make sure you thread them in straight and use an O-ring and it shouldn't be a problem.
  #29 (permalink)
Old February 23, 2007, 11:57 AM
Ok thanks. One more question honest lol. Which would you recomend the high flow fittings(which seem to have longer barbs) or the perfect seal.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
  #30 (permalink)
Old February 24, 2007, 11:58 AM
Misoprostol
Guest
Posts: n/a
Personally I like the perfect seal barbs simply because the actual inner diameter of both is exactly the same. High flow barbs is just a marketing term. They both flow the same. All the guys I know at Danger Den use perfect seal. They're just better.
Water Cooling Setup Overview Sting3r11 Water Cooling 10 November 28, 2007 08:52 PM
First water cooling setup. jubeix Water Cooling 6 November 16, 2007 06:22 PM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 09:22 PM
My new, long awaited water cooling setup! Wankerfx Water Cooling 12 September 5, 2007 08:44 PM
Another DIY Water Cooling Rig Magnesious Water Cooling 5 April 14, 2007 11:51 AM
