Old May 1, 2012, 03:29 AM
Default considering corsair h80
Hi guys I have a asetek 550lc and want to replace it. I was first planning on an h100 but the motherboard would conflict because on my nzxt phantom 200 mm fans. I wouldnt be able to mount 120mm below for push/pull configuration. Im considering on an h80 because it gets about the same cooling performance atleast on reviews. My 550 i hear is about the same as a h50 and my temperatures are fine but there is not such thing as to cool and am not going to assemble a custom loop for just a cpu as I dont have waterblocked gpu's. I am not sure about a performance difference between the 550lc and the h80. I know the 550 is probably not very popular at all and is considered a...low end watercooling unit? Im hoping for atleast a 10 degree difference but that might be pushing i dont know. My cpu at idle is 30 degrees lowest core being 17 degrees this is with window open. Window closed it raises 5 degrees. When gaming it gets 45 degrees on the hottest core. Any feedback is awesome and in the future I want to learn about this custom looping and stuff all ive used is this 550 and a no brand cpu cooler than i got with my ibuypower system. Im into assembling my own computers now though. (unless you get an erebus on ibuypower THERE COOLING OPTIONS SUCK i figured out lol) they say there h60 IS HIGH PERFORMANCE?????what age are they living in. Sorry about the ranting im typing everything that coems into my head. But yeah you can look at my specs on my other cpu i get 45 degrees idling on my 960. Low end watercooling unit and lexa s case kinda add to that. I dont get very good airflow in my lexa s. Yeah thanks this is a lot and am not even going to re read or paragraph and stuff its 2:00 am and im tired.
Old May 1, 2012, 04:13 AM
Slik's Avatar
Get the H80. I think you can find one for sale right here at HC. Check the For Sale threads.
Thermaltake Level 10-i7 3770k @ 4.4ghz Liquid cooled-2x8gb DDR3@ 1600mhz- Two EVGA Titans SLI - Xonar Phoebus Sound Card-Dell 3008 30" Monitor-Razer Tiamat Headphones-Butt Kicker Gamer-TrackIR 5
Old May 1, 2012, 01:52 PM
I just posted one I had up on B/S/T since I won't be using it anymore. For even better performance I would recommend getting better fans with the cooler too (gentle typhoons if you can find them).
Old May 1, 2012, 03:14 PM
Ok I right now am using 120mm apevia's with blue led's I got off of newegg. Tell me are they any good?
Newegg.com - APEVIA CF12SL-UBL 120mm Blue LED Case Fan
I hate they have molex connectors so i cant control off motherboard and am going to order the only molex fan controller I can find. What speeds do fans run with no controller? These seem to run kinda slow I mean there max is 1700 rpms. I will check out these other fans but if you knwo anything on my apevias do tell.
Ok jsut checked them on newegg ( i like newegg) and they appear to be deactivated. Do they have perhaps a newer better model?
why do i keep posting before looking lol the specs say they move lots of air and quiet. I didnt know scythe made such awesome fans.
Old May 10, 2012, 05:39 PM
Default GT's!
gentle typhoons seem to be the best for any radiator situation. noiseblocker PL-2's are also very good fans however, both of these fans will cost you a bit more than your average fan but they are well worth your money if you go with the GT's, 1850rpm seems to be the most common model (AP-15 i believe)
Defective Corsair K90 - Take it to NCIX or to Corsair? bigFOIG Troubleshooting 14 June 3, 2012 01:40 PM
Corsair A70 and Corsair 600T case Chasingu Air Cooling 3 May 1, 2012 03:37 PM
Corsair H100 vs Corsair H80 Linus LinusTechTips Q&A 22 January 5, 2012 04:00 PM
[FS] Corsair XMS3 3X2GB 2000MHz, Corsair XMS3 3X2GB 1333MHz bombdigiti Buy/Sell & Trade 12 July 18, 2011 10:47 PM
Corsair Showcases Computer Build with the Corsair 800D and H50 FiXT Press Releases & Tech News 2 October 2, 2009 12:22 AM
