Old April 29, 2012, 07:25 AM
Your best bet is going to be Fastenal. I would suggest the store on 39 street and 53 Ave. Manager there is a good guy.
Old April 29, 2012, 11:20 AM
Behemoth do you know what the minimum order is?
Old April 29, 2012, 01:00 PM
I don't believe they have a minimum order. How many are you looking for anyways? I have a 8 in my room collecting dust and would gladly give them to you. They are 35mm long though.
Another place you can go to is Base Industrial. They don't have a minimum order and have awesome prices. They're just off 91st and argyll.
Old April 29, 2012, 01:18 PM
Thanks a bunch dude.
Old April 29, 2012, 01:46 PM
Your welcome!
Old April 29, 2012, 09:49 PM
Fastenal is where I got my M4 as well. What length you looking for? I know I bought a hundred and there is no way I'll ever use that many. They are black Pan Head, M4-07 x 30mm I believe. Not sure if that is the size your looking for or not, but I'll lettermail you how many you need to mount the rad. Send me your address, unless that size doesn't work.
Old May 1, 2012, 01:27 PM
I would check out Rona they had them in everything from 5mm to 25mm at my local store. No blacks though.
Intel i7-970 4.0GHz 1.25V | Asus Rampage III Extreme | Corsair Dominator 12GB | Asus 7970 DCII Crossfire | Western Digital 1TB Caviar Black | Seasonic X1200 | Lian Li X2000F | Microsoft Windows 7 Professional x64
Old May 1, 2012, 01:31 PM
Awesome I'll check rona first as there is one right by me if I ever need to. Thankfully the gentleman at FrozenCPU sent me out some replacement screws.
Thanks for all of the suggestions everyone. Now I have a handfull of places to look in the future if I need to, which I'm sure i will.
H60 fan screws jtktam Water Cooling 11 February 19, 2012 06:54 PM
GPU Screws xilocient Video Cards 8 February 2, 2012 10:03 AM
Rad screws? Birk Water Cooling 13 January 8, 2012 10:07 PM
[WTB] Stock HS w/screws for 8800GT/GTS , or Just Screws! Soultribunal Buy/Sell & Trade 15 October 29, 2009 01:48 PM
help with screws phantom_jo Off Topic 9 May 7, 2009 09:41 AM
