Old May 1, 2012, 11:35 AM
WhippWhapp's Avatar
My line of work involves industrial coolant systems with millions of dollars worth of equipment on the line if there's a failure. Not once have I ever had an engineer recommend a parallel flow across multiple heat exchangers or condensers.
My vote is on series.
If you're worried about pressure drop on multi block systems, look at adding another pump, or a multi inlet reservoir and a manifold to split flow in the loop.
Swiftechs H2O-X20 Edge HD Series kits have the manifold integrated in the block, with multi inlets on the res.
I rub and whack and choke and stroke!
Old May 1, 2012, 05:45 PM
I think I will go with the cheaper option for now and see how it runs. Thanks very much for the input fellas. This is my 1st kick at the dual vid water cooling. Just wating to hear back from Dazmode about EMT.
My stuff for sale.
Mah Rig
Old May 1, 2012, 07:53 PM
parts ordered should be here soon!
My stuff for sale.
Mah Rig
Single Loop or Dual Loop? Pump enough for single? MattC Water Cooling 5 May 31, 2011 07:19 PM
Copper block discussion related to oxidation (NOT EK discussion or flaking) Varroa Water Cooling 8 May 31, 2011 05:20 AM
Another loop order, single/dual loop thread... turtletrax Water Cooling 8 July 28, 2010 08:40 PM
Discussion: What was the best (%OC) cpu? Cowboy CPU's and Motherboards 26 August 16, 2009 05:30 AM
HCF F@H discussion Supergrover HardwareCanucks F@H Team 205 June 19, 2008 10:08 AM
