Old April 24, 2012, 11:03 AM
Pabz0r545's Avatar
Default Where can I get black clamps for barbed fittings?
As the title states.....
And is it safe to do no clamps on barbed fittings?
Old April 24, 2012, 12:18 PM
stoanee's Avatar
Try Direct Canada
heatware
Old April 24, 2012, 12:41 PM
SugarJ's Avatar
I use black zip-ties, and no.
Old April 24, 2012, 02:04 PM
Pabz0r545's Avatar
zip ties is a good cheap idea. I think I'll go that route unless the ones at direct canada are cheap enough. Unfortunately I cannot connect to their site right now.
Old April 24, 2012, 02:31 PM
botat29's Avatar
are you talking about those one ?, I find them sexy
Old April 24, 2012, 03:50 PM
Soullessone21's Avatar
I have boxes and boxes of the plastic black clamps that come with watercooling kits I will take some pix in a few hours when I am home
Current Build:http://www.hardwarecanucks.com/forum...cube-gods.html
Always up for a Beer in Calgary or Area
“Two possibilities exist: either we are alone in the Universe or we are not. Both are equally terrifying.”
Old April 24, 2012, 04:26 PM
Pabz0r545's Avatar
Those aren't what I was talking about but I do find them sexy as hell. Where can they be purchased? I am obv trying to do this without spending much otherwise I would just go compression.
Ooh OOh thats exactly what I was asking about. If I could purchase some from you that would be great.
Old April 30, 2012, 04:01 PM
Pabz0r545's Avatar
I found those sexy ones at frozenCPU for 2.25 each! I ordered a bunch.
Old April 30, 2012, 06:10 PM
Just an FYI. You can get compression fittings for real cheap from NCIX. Bitspower BP-CPF-CC5 G1/4 to 1/2IN Straight Compression Fittings -SILVER SHINING- (Pair) - DirectCanada
Old April 30, 2012, 07:05 PM
Pabz0r545's Avatar
Thanks for the heads up. I need all black because I want a super nice build and hope to look as good as lowfats :)
I went ahead and ordered all of my fittings already today. I ended up going with barbed because the angled compression fittings are quite pricey and I got a few of them. And with those little clamps it still worked out to being a good deal cheaper.
What Size Hose Clamps for 1/2"ID 3/4"OD Tube with 1/8" wall r3quiem Water Cooling 9 December 20, 2011 02:42 AM
ASUS Rampage III Black Edition, Back In Full Black FiXT Press Releases & Tech News 24 April 29, 2011 03:08 PM
[WTB] Bitspower matte black 45 or 90 rotary fittings. tragd Buy/Sell & Trade 0 September 22, 2010 12:16 PM
[WTB] Swiftech hose clamps... freeloader1969 Buy/Sell & Trade 5 June 4, 2010 05:30 AM
wormdrive hose clamps nikitos Water Cooling 6 June 19, 2008 11:16 PM
