Old April 20, 2012, 12:15 PM
Default is it better 2 rad MCR320 or 1 XSPC RX360
Hi i am doing a new rig and want to know if it is better cooling with 2 swiftech MCR320 in one loop or 1 XSPC360 performance? They will be standing on the bottom of my TJ11.
Notice that i already have one MCR320 from my old rig that i can match with a second MCR320 i'll sanwich between them a set of 3 fans and form one side of one of them a set of 3 fans
any idea ?
Old April 20, 2012, 12:28 PM
lowfat's Avatar
Two MCR320's will be almost twice as good as an RX360. However sandwiching radiators is useless. I'd just stick w/ the single MCR320 you already have.
Old April 20, 2012, 12:31 PM
Adzsask's Avatar
Don't sandwich your rads, if you want lower speed fans then the RX360 is better, otherwise leave her be.
Old April 20, 2012, 01:09 PM
Ok i'll keep my old MCR320 since i'm only cooling the i7 3820 and my HD 5970 that will be enough I hope.
But the TJ11 don't have any bracket to hold the Rad !!! anyone have some idea ?
Old April 20, 2012, 01:25 PM
SugarJ's Avatar
UN Designs Rad Bracket
or
Universal 120mm Radiator Stand - Black Universal 120mm Radiator Stand - Black [RADSTAND-120] - $14.99 : DazMode, The Best Canadian PC Watercooling and Modding Store!
Old April 20, 2012, 01:29 PM
Cool thank you i'll get the XSPC seams mor solid :)
Old May 12, 2012, 02:12 AM
Hmm , my loop is now cooling the i7 3820 and 2 x amd 5970 with 1 mcp655 and 1 MCR320(the quiet version not the xp) and it is getting hot, a little bit!!
what is better ?
add a MCR420 to the MCR320 and silent fans and probably a second mcp655
or keep only the MCR320 and add push pull fan
Old May 12, 2012, 07:38 AM
lowfat's Avatar
what is better ?
Push pull won't gain you a lot. Maybe 1-2C. If you have room to add a second radiator then do it. It will definitely be the best thing you could do for the loop. You really don't need a second pump unless you want the redundancy.
Old May 12, 2012, 09:02 AM
Adzsask's Avatar
what is better ?
should have picked up an XSPC RX360, love mine and keeps even my 130 watt i7 nice and cool.
Old May 12, 2012, 09:14 AM
lowfat's Avatar
It wouldn't have been any better. The MCR320 is no slouch. It is within 1-2C of the more expensive radiators, even w/ lower speed fans. He has 4GPUs and a 3820 on a single 3x120mm radiator. That is a substantial amount of heat for any triple 120mm radiator.
Haf X XSPC RX360 Rad Question Chomie Case Mods, Worklog & Gallery 14 April 30, 2012 08:16 PM
dazmode raystorm RX360-D5S kit r3v07ut10n Water Cooling 17 March 20, 2012 07:45 PM
mcr320 with 3 or 6 fans (without shroud) CTA Water Cooling 10 October 18, 2010 07:37 PM
[WTB] looking for used mcr320 Ken_C Buy/Sell & Trade 10 May 7, 2009 01:49 PM
3x MCR320's internal...DONE flclisgreat Water Cooling 11 August 31, 2008 03:48 PM
