Old April 19, 2012, 11:52 AM
Default Bitspower TRUE GOLDEN Compression Fitting
hi any one knew a place to buy Bitspower -TRUE GOLDEN- G1/4 Straight Compression Fitting for 3/8IN ID 1/2IN OD i only found 3/8IN ID 5/8IN OD and i thonk we can not buy directly from Bitspower ? any Help
I realy Hope Dazmode can get some of them for me
Old April 19, 2012, 01:22 PM
canada2005's Avatar
You should be able to buy from Bitspower directly if they have any. On the website you must sign in, then use the contact button and tell them what you would like to buy. They will then send an invoice for the amount and then you pay.
Old April 19, 2012, 06:32 PM
Good luck, 3/8ID 1/2OD isn't a popular tubing size. E-mail dazmode and he should be able to get some for you.
Old April 19, 2012, 07:48 PM
DTI DTI is offline
Try Computer Water Cooling - FrozenCPU.com *
most of my fittings came from here
Old April 19, 2012, 07:51 PM
it is because 3 years ago that was a standard 3/8ID 1/2OD and got all my black bitspower compression fitting then with right angle and all the 45degree i have a total of 14 and 2 90 deg angle payed a lot of moeny for then and don't want to sell and buy others :(
Old April 19, 2012, 09:05 PM
You can buy direct from bitspower.
Bitspower Taiwan On-Line Shop
Old April 19, 2012, 10:30 PM
WAW it is not easy to buy those lol. I think I will probably buy 2 pair of 3/8 to 5/8 to use with just the CPU block (that is gold plated) and one will be at the input of the graphic card the other in the output of the pump. And I will keep the rest of the loop on 3/8ID to 1/2 OD since the entire loop will run on 3/8 ID I hope there will be no problem of flow?
Can i do that?
Any recommendation?
Thank you
Old April 19, 2012, 11:35 PM
bundymania's Avatar
Sidewinder Computers should have them in stock
Old April 19, 2012, 11:54 PM
Hmm no one form the big stores have them in Canada or Us I checked at: Sidwinder, performance pc, frozenCPU, NCIX, Dazmode ...
I found 3/8 ID 5/8 OD,
I found 1/2 ID 3/4 OD
I even found 7/16 ID 5/8 OD
but not the 3/8 ID 1/2 OD
Old April 20, 2012, 05:17 AM
If you're willing to change colours, you could always buy silver ones from dazmode and paint the whole lot.
[WTT] Bitspower Compression fitting medwes Buy/Sell & Trade 0 April 18, 2012 02:08 PM
help with leaky tfc 45 rotary compression fitting! antiacid Water Cooling 7 May 11, 2010 11:49 PM
Bitspower Compression Fitting Question Jmark Water Cooling 9 October 19, 2009 03:36 PM
[FS] Bitspower Compression and other fittings mhw100 Buy/Sell & Trade 1 July 15, 2009 02:16 PM
[FS] Bitspower compression and other fitting mhw100 Buy/Sell & Trade 12 June 22, 2009 07:41 AM
