Old April 16, 2012, 12:00 PM
Originally Posted by jonny.nguyen2 View Post
what are my odds this mobo is F'd??
what could happen if i continue to use it with the crushed caps?? fire??
thx
Not fire but they could explode if they're liquid caps. Solid caps it'll probably just blow a fuse or brick the board when u turn it on.
Good luck man, this is the most tech of all tech problems; soldering something to you board.
Old April 16, 2012, 02:54 PM
Piderman's Avatar
If your not down for doing it yourself take it to a electronics store that sells the capacitors in your area and I am sure someone there would be willing to help you out too.
That is a bad situation I hope you get it working with out much trouble.
Old April 16, 2012, 05:24 PM
yycraven's Avatar
He has 4 capacitors damaged if you look closer you will see the other two one on each side that have nicks in them, so better make sure to replace them. I would just RMA the board if it still has warranty.
ASRock Extreme 3,2500K,NH-D14,Patriot G2 16GB ,WD 750GB,640GB Sata ,2 GTX 470 SLi Thermaltake toughpower XT850W,Tech Station. V243H,2253LW LCD
heatware
Old April 16, 2012, 06:05 PM
gingerbee's Avatar
yes he has and clearly it is ok cause you were running it before were you not ???? and if so then it was clearly working
Old April 17, 2012, 02:17 AM
maverick_brent's Avatar
I personally think that you should not RMA the board, I think it will be a complete waste of time as the manufacturer will see the "physical" damage and deny under warranty, they may replace while charging you a shit ton in warranty and labour...IMHO.
Old April 17, 2012, 05:12 AM
it was running perfectly right up until is dismantled it for mods.
i'm just gonna rotate the H100 upon reinstall and run it.
i will shut it down when not in use.
i have three fire extinguishers within reach in the command centre just in case.
thx guys for all the info.
John
Old April 17, 2012, 06:08 AM
b1lk1's Avatar
You cannot RMA something YOU physically damaged. People wonder why companies are getting strict with RMA's and this is why. If you broke it suck it up. If it fails while in proper use then RMA it.
MY HEATWARE
Old April 17, 2012, 06:09 AM
gingerbee's Avatar
no if it was running your fine the damage was there well running so i guess the bent caps wont matter they didn't before so why would they now and ya if you can just rotate it so this doesn't happen then bingo your good to go
edit ^^^^ amen to that if i break it oh well guess i should have done that lmao
  #19 (permalink)
Old April 17, 2012, 02:27 PM
ouch, that does look painful :S
Should i get H100?? carlosespada12 LinusTechTips Q&A 7 April 20, 2012 02:39 PM
H100 trayton Water Cooling 19 March 5, 2012 11:55 AM
H100 HELP NEEDED! jef.paas Water Cooling 3 November 14, 2011 08:20 AM
H100 install Mod... jef.paas New Builds 0 October 31, 2011 05:10 PM
